Question about Amana AFD2535DES French Door Refrigerator
Water despenser is apparently frozen
1) No water comes from the water dispenser. 2) Left vegetable crisper freezes vegetables. It seems that the water may be frozen in the lines. The temperature in the refrigerator is within the normal range. The water filter is overdue for change.
  • Anonymous Mar 27, 2014
    AFTER TWO DAYS VEGETABLES OR ANYTHING IT WILL BE SPOIL. LIKE A VEGETABLES PUT IN WATER. HOW IT WILL SOLVED.
  • 706 Answers
You may have two mutually exclusive probems... one being the water dispenser doesn't dispense water... As you stated, the obvious remedy would be to replace your filter to see if that is restricting water flow.. secondly, your vegetable crisper is freezing vegetables... chances are that the inlet between the freezer compartment and that vegetable darwer is near there and the damper needs to be closed a bit... See if you can locate the cold air inlet vent and partially close the damper ... Hope that helps...
Posted on Aug 14, 2008
SOURCE:
How many grams of frozen mixed vegetables are in one cup?
225 grams
Frozen vegetables, diced cup measurements and equivalents in ...
www.cookitsimply.com > Measurements > Frozen vegetables
amount, in grams (g), amount, in ounces (oz). 1/8 cup, 20 g, 0.7 oz. 1/4 cup, 40 g, 1.3 oz. 1/3 cup, 50 g, 1.8 oz. 3/8 cup, 55 g, 2 oz. 1/2 cup, 75 g, 2.6 oz. 5/8 cup ...
Convert 1 cup to 1 g, gram of Vegetables, mixed (corn, lima beans ...
www.traditionaloven.com/foods/.../cup/...gram/veggies-mixed-corn-lima-beans-peas-... Amount: 1 cup of Vegetables, mixed (corn, lima beans, peas, green beans, ... Multiple measuring units converter for converting all amounts of Vegetables, mixed ...
Mixed vegetables Nutrition Information - Eat This Much
https://www.eatthismuch.com/food/view/mixed-vegetables,2256/ View the nutrition for Mixed vegetables, including calories, carbs, fat, protein, ... Mixed vegetables. Frozen, unprepared ... For a Serving Size of 1 cup (225g). How many grams of frozen mixed vegetables are in one cup Google Search
Nov 06, 2017 | Computers & Internet
Water dispenser frozen?
You have a resevoir inside the fridge compartment that needs to be defrosted. It is frozen.
It is usually located behind the crisper drawers.
It is a small plastic tank that is white about 6 inches or so in length and bolted on to the wall behind the crispers.
A hair dryer usually does the trick in about 10 mins.
Regards
Brian
Aug 06, 2008 | Jenn-Air JFC2089HE French Door...
Can a frozen lasagna be refreeze after cooking?
Yes that is ok! Because it has been cooked you are ok, the rule is do not thaw out frozen products and then re Freeze!
Dec 30, 2014 | Nestl? Stouffers Vegetable Lasagna 10.5...
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Crisper drawers are feezing vegetables.
look down at the bottom crisper and there should be an air control that lets more or less air in from the freezer section. close this control down so that most of the air stays in the freezer. some models may say meats(colder) and vegetables(warmer).
some models the control in the down position opens up the vent more allowing it to get colder and in the up position closes the vent down more allowing less cold air into the refrigerator. you can remove the crisper and experiment with the control.
Jul 14, 2010 | GE Profile¿ Arctica® Energy...
Vegetables in fruit and vegetable bin is freezing.
I solved my problem by going someplace that wasn't going to charge me!
Jan 07, 2010 | Amana AFD2535DES French Door Refrigerator
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
Amana AFD2535DES French Door Refrigerator Logo
722 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
