Question about Amana Refrigerators
I have a 13 year old refrigerator with an icemaker. I installed a water line to get water to the fridge. The hose is connected to the water main and the fridge. I am not getting any ice.
  • 706 Answers
Obviously, your ice maker problem could be any number of things... Now that you have water to the ice maker, is the inlet valve opening to allow water to get to the ice maker itself? If it is, is the line that runs between the inlet valve free to allow water to get to the ice maker? if it is, is the ice maker cycling ( meaning the motor rotates the drive mechanism that times the cycle of opening the valve, rotating the mold tray then releasing the ice with a small mold release heater? An ice maker that's ~ 13 years old probably has a removable front cover so that you can see the drive gears.. Also, is the lever that senses the ice cube bin is over full in a position ( normally down) that allows th eice cube maker to cycle? Hopefully, these simple checks will help you trouble shoot the problem and get your icemaker functioning again. Hope this helps !
Posted on Aug 14, 2008
How do I hook up the plumbing. Do you have an exploded diagram of the back panel where all the water hook ups are at.
It depends on the refridgerator. Some have two inlet valves. Basically, you have a water line from the home. Usually copper line. You also will have two places for water lines on the opposite side of the inlet valve. Sometimes you may only have one. The line leading from fridge ( if ice and water through door) will hookup to the line where you have the fridge connactor. The quick connects to the inlet valve. The second one will be for ice maker. That water line runs up the back of fridge into freezer. Make sure you place the quick connects in the right spot. Process of elimination because some inlet valves wont let you change the hoses once installed. Connect the main water line from the home. Connect both quick connects dont connect water lines yet. Push the water thru the door botton and see which valve opens on the inlet. Which valve on inlet opened and allowed water to come out. That is for fridge and other is for icemaker.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Refrigerators
Ice maker is producing ice but not dispensing ..filter symbol is being displayed..Any guidance would be appreciated
order a new icemaker, about 100.00 from parts company, heat element not working to help release ice. Its an easy fix and will save you a service call for 150 additional bucks. Its a matter of taking out old one. First turn off water valve to fridge. Take out old icemaker and remove electrical supply, just a squeeze and the clip should come out. Place new electrical connection, connect water supply line, turn on water line to fridge fridge, the compartment should fill and then ice in about an hour or 90 min.
Feb 09, 2011 | Samsung RS2630SH Side by Side Refrigerator
The electricity went off yesterday while we were gone (not sure how long) and the freezer is no longer staying cold. The ice maker hasn't made any ice and it has melted on top of the other food. We have a...
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | GE Profile Arctica 25.4 Cubic Feet...
How to replace an icemaker hose
Turn water off from the supply. There should be a valve that the 1/4" water line connects to, if not you will have to shut off the water main. Using a wrench remove the nut from the water line connection (usually a compression fitting. You will need a need compression sleeve with the new line x2, one for the valve and one for the fridge. Next disconnect the line from the back of the fridge. Run the new line the same way the old one was run, for easiness. Make sure you leave enough slack behind the refridgerator to allow it to be pulled out and cleaned behind. Once all connections are tight you can turn the water back on and ensure you don't have any leaks. Hope this helps.
Mar 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Hooked up waterline to side by side frigiedaire,
Jun 12, 2009 | Frigidaire GLRS264ZA Side by Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker dont work after power outage
Make sure the ice bail wire is not lifted. If it is, the ice maker will not make ice.
The water valve may have failed to. It's in the bottom back of the refrigerator, and the water line normally connects near where the valve is.
Let me know what you find.
Jan 30, 2009 | Refrigerators
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
106 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
