Question about Konica Minolta DiMAGE Z6 Digital Camera
No card message when card inserted
I'm getting a 'No Card' message whenI have a memory card inserted.
I have also tested the three different memory cards in another camera where they work fine.
The contacts for the sd card side camera is dirty, or the it may be shut off in the setup menu
Posted on Sep 05, 2008
I'm using for sand disk micro SD 2GB (NEW) card.the memory card open in my mobile phone(Nokia N73). smooth working.but the memory card not open in my computer. start-menu-my computer-removable...
I've been encountering this issue. The problem may come from the card reader or the card holder. If possible, use a different card holder and of problem persists, try a different card reader or test on another computer.
Hope this helps!!
May 08, 2011 | SanDisk 2GB microSD Memory Card
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
I get a "Memory card error" message on my SD750?what could be the problem with my card and can it be solved?
The reason there is an error message on your memory card is because the memory card might have been damaged or probably not inserted properly.
To find out if the memory card is damaged, try to use the memory card in other devices that supports the memory card to see if it works. If it works on other devices, then the problem if from the card reader that is in the camera, and if it does not work, then the memory card is faulty. And the only solution is to replace the memory card.
To test the slot in the camera, try a tested okay memory card on it, if it does not work then the slot is faulty and to solve this problem, i will strongly advice you take the camera to a camera repair guy to clean the slot for you.
Goodluck
Sep 13, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory card error
Having gone over a month with no response, I assume it was just a matter of SD versus SDHC cards.
Jul 17, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Hp photosmart 3210 all in one memory card error no memory card is inserted but this error message persists
Try the same memory card in a pc to check if it works ... if it does then check the slot where the card gets plugged in... try a different card that also does not work means printer memory card slot is bad
Apr 29, 2010 | HP Photosmart 3210 Printer
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
Apr 12, 2010 | Samsung S630 Digital Camera
Memory card not working
If you're sure the slide switch on the side of the card is in the unlocked position, try this. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Apr 05, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
My ps2 memory card won't work wheni put it in it says no data on browse screen and no memory card inserted when i play a game.i have tried it in slots 1 and 2.
your memory card i think has got corrupt. u will have to format it either from a the game options windows or connect it with a computer n format it and then try it again.
Nov 01, 2009 | Sony PlayStation 2 (PS2) Console
Memory card error
Same problem here with Micro Memory MMSD/4GBHI card. What to do?
Feb 02, 2008 | Canon PowerShot A620 Digital Camera
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
123 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
