Question about Samsung HLP4663W 46" Rear Projection HDTV
No picture on my hlp5063
Checked the lamp annd the color wheel all working but no picture!!!
  • 31 Answers
You might need to replace the lam anyways. if you looking the back do you see light through the vents when you turn it on??
Posted on Aug 14, 2008
Why is my picture color distored color?????????
Your color is distorted because your color wheel is probably going bad. Try resetting all the picture values first. Sometimes they need to go back to normal when the lamp is changed. Lamps only provide white light and have no bearing on colors unless they are very dim. Also check your cables. a loose or bad cable can cause this as well. Lastly make sure your new lamp is made by Osram or Philips. knock offs wont work.
Feb 21, 2015 | Mitsubishi WD Televison & Video
Samsung HLR5067WX DLP - No picture, lamp light flashing
The colour wheel will not spin until the light has lit. The light will not ignite if the ballast unit detects a faulty fan, (checked) or the lamp door is open. The processor must be working as the lamp light flashes so I would say, ballast especialy if the lamp that came out is physically broken. Not cheap, even from flea bay!
Dec 06, 2013 | Televison & Video
Samsung hlp-5063w no picture when its on
Do you have three flashing lights on the front? You most likely have a problem with your lamp or color wheel. Those two component combined are pretty much the guts of your TV. If you are handy, you can replace those parts yourself. I have a 50" Samsung DLP and I've already replaced those to items myself. Otherwise, you can contact Samsung at 1-800-SAMSUNG and they can assist.
I bought my parts using Amazon, had them shipped to me, and took an afternoon to take about the back of the TV; documenting everything and taking photos of the progress, until it was done. There may be video tutorials on Youtube. There was for my model (HLS5086). Here is a great link to help you along. Good luck.
http://blog.trebacz.com/2011/01/50-samsung-dlp-hl-p5063w-with-3.html
Nov 19, 2013 | Televison & Video
MY SAMSUNG HLP5063 HAS SOUND BUT NO PICTURE ON ANY SOURCE OF MEDIA
have you replaced the bulb already this lamp are made to last 6000-8000 life hours and if you have not replaced the lamp yet that would be the first place to start,here is the lamp you need just in case
http://www.discount-merchant.com/Samsung-BP96-00608A-Lamp-Enclosure-p/samsung-bp96-00608-lamp-enc.htm?1=1&CartID=0
Oct 26, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
I have a Promethean Interactive Board in my classroom that is paired with an Epson 83C projector. The picture that is blurry. How can I focus the picture on the Promethean Board? Thanks!
the light is blerry ,
Pls check the lamp,(if it is bright enough )
check the color if it is correct and brite-colored (if the LCD panels is work well)
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Oct 01, 2010 | Epson 5300 7200 7300 Replacement Lamp -...
We own a Samsung DLP-TV. Last night it started shutting itself off. WE changed the lamp, but it is still shutting itself off after a minute. First, the picture goes off black, then the entire TV shuts off....
Do you still have your old lamp? try to see if it still works.. i think the problem could be something with your Ballast or maybe the color wheel.
Does your TV makes a strange sound? if it does maybe one of those 2 ballast or color wheel.
LETS TRY THIS....... MAYBE IT WILL WORK.
the Door lamp switch could be faulty, you've got to check it need to close fine with out the switch to go down
here is a picture that i found it looks like this!
and if not.. you can probably call this number the will give you free service.. i have tried it before =] (800) 281-8860
Mar 09, 2010 | Samsung HL-T5675S Television
I have a samsung dlp when i plug it in i see the fan go on and also here a hum is that the fan or color wheel? andy way the lamp goes on and no picture. the lamp light is on in front. how do i know if it...
Check this link it may help - also if your lamp is trying to light you should see some light and hear a sparking noise from the board (ballast board with spark gap lighting)the lamp is plugged into (internally).
Samsung Color Wheel
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Nov 06, 2009 | Samsung DLP HL-P5663W 56" TV
My picture won't show after replacing the lamp
Actually that humming sound was not the lamp, the humming sounds come from color wheels when they're going out, and since the color wheel is part of the light engine system and it's not working, that's why you don't have an image, you'll probably ask your self why, since it's not the lamp.. the thing is that the light engine system is componed by lamp, ballast, color wheel and dmd board, so when one of these doesn't work, there will be no image reflected, because they work together
Jul 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
TV shuts itself off
Something is overheating or you've got leaking capacitors somewhere. I'd start with the ballast board. Its directly underneath the lamp housing. You can access and remove it through the lamp door. Replace that and if that doesn't solve the problem, comment again, and we'll move on to more complicated repairs. You haven't noticed any weird noises, humming, screeching or similar oddities from the set? Turn the set on with the lamp door open and bypass the switch with a piece of tape, if you hear something like a hum, you may have a bad color wheel motor.
Jan 16, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung hlp5063
That means that the color wheel, ballast and lamp are working properly. It seems more like a video source failure or one of the thermal sensors that is mounted on top of the color wheel assembly.
Will keep you posted about my findings with my TV.
Aug 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W 46" Rear Projection HDTV Logo
98 people viewed this question
Henry  Thomas
Henry Thomas
