Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water continues to run
When the button is pushed water continually runs everywhere
  • 74 Answers
Sounds like the microswitch needs adjusting
Posted on Aug 28, 2008
6ya staff
SOURCE:
Admiral dryer won't heat. Fuses have continuity. Does run though. Heating element has continuity as well. Have both legs of power going in.
Check the high limit switches next to the drum and element. they are around the size of a quarter dollar, about one and a half inches. check continuity.
Jul 07, 2016 | Admiral AED4475TQ
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
Hi I have a Simpson 7.5kg top loader machine model no 22s701E. The water keeps continually filling. I have to turn the taps off for it to stop otherwise it overflows everywhere.
Water inlet valves operate when power is supplied to them. If you turn the machine off or pull the plug and the water stops it means that the inlet valve is ok. If the water continues to run with no power to the valve then the valve is faulty..
Replacing a crook inlet valve is not a big job for a tech..
Good luck....Nomess
Aug 03, 2010 | Washing Machines
The drain pump runs continuously when the Dishlex Global 300 dishwasher is turned on. When pushed, the buttons on the control panel would not change any of the cycles.
This could be that the anti flood device "polystireen float and micro switch at the base has detected water at the bottom due to a leak (pipe or pipe clamp). This device puts the washer in pump out mode and will not continue. Firstly you need to determine what causes the water leak and rectify it before it will continue.
Mar 20, 2010 | Dishwashers
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
Leaks water out all the time. Clothes wet or rust marked.
OMG, how frustrating to be ironing and water shoot out everywhere from this iron....So, to remedy it, I have turned off the steam, use it as a dry iron, and have a spray bottle handy to spray as I iron...love the feel of this iron, but hate the water everywhere...
Sep 02, 2009 | Euro-Pro Shark GI490 Iron
Cleaning solution continually runs from clean solution tank
Where is the water running out? If at the bottom of the tank, is the seal on where the tank sits on, Maybe the rod inside the handle is staying pushed down, the reservior asm is bad, or a water line is off.
Feb 12, 2008 | Hoover F5881-900 Vacuum
No water coming out of water filter
Please share the make and model of your filter.
May 19, 2017 | Water Filters & Coolers
check to see if the filter is in backwards! most inline filters flow only one way!
Dec 18, 2007 | Kitchen Appliances - Others
Stuck in drain cycle
continuous pump action is a sign that there is another fault with the machine, generally its a faulty heater element, test accordingly hope i have helped, if so please rate, me, be safe unplug when working on any appliance
Sep 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
GE (PSS26MSRSS) Side by Side Refrigerator Logo
59 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
