Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water wont dispense
This morning the water was working and no it wont dispense. i checked the water at the back and its working. if the filter needs to be changed, would it make the water stop?
  • 706 Answers
Yes, if the filter gets clogged up to a point that it won't allow water to flow, it won't dispense. Replace the filter. Remember that the all the junk that the filter captures is better left in the filter than in your bloodstream... Hope that helps !
Posted on Aug 14, 2008
Ice maker not working on Frigidaire frs26kr4a
Good Morning Friend,
I understand that the ice maker is not working on your Frigidaire refrigerator, model# FRS26KR4A. First, make sure the wire signal arm is in the down or on position. Secondly, make sure your household water line is open. Thirdly, make sure your freezer is cold enough to keep items frozen. Fourthly, check the saddle valve, if there is one, to make sure it is not clogged or restricted by any foreign material. Lastly, Check to see if the water dispenser is dispensing water. If no water is being dispensed, the water filter could possibly be clogged and would need to be replaced. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire FRS26KR4A Side by Side...
Samsung french door refrigerator wont disense water after replacing water filter
Put the old one back in and if water works, then the new filter is blocked. Buy another filter.......
Jan 11, 2014 | Samsung RF4267HARS 27 cu.ft. French Door...
Whirlpool ED22DQXEW01 Water Dispenser Problem
CHECK WATER FILTER/// IF GOOD BAD WATER VALVE
Jun 18, 2009 | Whirlpool ED2FHEXN Side by Side...
GE Profile Refrigerator water dispenser stop working...
This could be a bad water valve on the back of refrigerator or the dispenser is not asking the water valve to open. There are 2 valves in back, one is for ice maker and other is for the dispenser. I will help to try to locate the problem if you need, let me know, Thanks, Sea Breeze
Mar 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser wont work....ice maker works
Need to check and see if the water filter is stop up ,if you don't have a filter it I would start with water value at the bottom .
Mar 14, 2009 | Refrigerators
Water dispenser stopped working after changing filter
There is a built in system of valves on the filter connections that enable changing filters without turning off the water. IF the filters are not fully connected the valves wont open and there wont be any water flow. .
Feb 17, 2018 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
The water dispenser in my frig stopped working but it still makes lots of ice. I replaced the filter on 29 Dec 2007. I normally get 6 months out of a filter.
We had same problem! The water line gets frozen in the door, and there is no way to get to it. But, I took some 14 gauge electrical wire and would get one end hot by putting it under hot water, then put that end up the water line in the door. This might take several attempts, but it will work. A little piece of ice about 2 inches long will come out.
Mar 05, 2008 | GE CleanSteel GSL25JFTBS
Have the same problem with the water dispenser
Just went through the same thing but mine is a Frigidaire (Electrolux). The tube within the freezer door was frozen up. There is a connection behind the left corner of the front grill that can be taken apart. I put the end going to the dispenser into a pan of hot water for about 15 minutes and got flow back. I just hope it will work again in the morning.
Feb 12, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
119 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
