Question about Dell E173FP 17" LCD Monitor
Lamps i have the same problem with my E172fpb. how can i check if the lamps are busted?
    Champion:
  • 293 Answers
Evrey,
Well, actually it not the lamp itself. Check the inverter ( what's the inverter?) It's a power supply were you plugged your power cord into. Ok! Now you know what the inverter look like. Next inspecting all the capacitors see if any has a stress marks on top of the caps, like a pluffed or a burst. If you find a busted caps...replaced those caps. If not sure...just replaced all the caps. Good lucks!
Posted on Sep 25, 2008
Have a wd60638 changed the lamp because old one busted now the TV works fine for about 3-5 minutes starts to hum and a clicking sound and pictures begins to flicker with colors going in and out
normally no bulb will bust ever unless you have oil on the lamp. sooo , it got too hot then. even if the fans turning its not putting out.
check the exhaust it should blow a lot of air past the lamp.
Oct 19, 2014 | Mitsubishi Televison & Video
My sanyo PLC-sw20a lamp does not light after turning on, the red lamp indicator still lighted and there is no indication for lamp replacement. Is the lamp busted?
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 20, 2011 | Sanyo PLC-SW20A Lamp
I have sound not picture and a flashing green led light
it seems like lamp failure. please do check lamp, if busted replace a new lamp.
Sep 04, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The power light on our model E172FPb Dell monitor is blinking. The screen does not turn on. What could be the problem
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Boards: www.lcdrepair.us
May 19, 2010 | Computers & Internet
The screen goes black, but the TV is still on, and the audio is still working.
open the back cover of your tv...and look for the power supply..the inverter is connected to the power supply via 24volts supply..solder the supply terminal.and push the connector of the inverter supply to its socket...perfectly!next check wheter your backlight lamp are busted replace busted lamps.this lamps illuminate the screen of your monitor.
hope this could help you good luck!
your rate is important to this post pls.
May 21, 2010 | Televison & Video
EPSON ELP5000 bought from surplus; plug it in and the power indicator glows orange and the lamp indicator is not lit. Opened the lamp unit and it is clearly blown. The user manual indicates that the lamp...
It is an indication that the projector is in sleep mode. Press power button and check for any changes on the led indicators. If the power turns red, it means unit is hot. check if the fan is working and if the air filter is clean or needs cleaning. If the lamp turns red it means the lamp is busted, You will experience this since lamp is clearly blown. But if both lights are red, it means that the unit is busted and will require service.
Mar 26, 2010 | Epson Replacement Lamp Projector Lamp For...
I have a Dell E172FPb flat screen monitor. The
There are two possibilities, one is bad caps in the power supply, number two is shorted out transistors (P/N c5706/5707) in the inverter circuits. Please open it up and report back what you see so we can guide you further, see example fo failed monitors due to bad caps, lamps, etc: http://s807.photobucket.com/home/budm/allalbums
Jan 30, 2010 | Computers & Internet
Tv was on and shut itself off. it now wont turn on. the green power light comes on then clicks off after 1 or 2 seconds with no picture ever coming on
The lamp is busted. Check and replace. Contact your dealer for lamp replacement information. Dispose the busted lamp properly. It contains mercury. Call your local authorities for proper disposal.
Aug 02, 2009 | Mitsubishi WS-48313 48" Rear Projection...
Scanning lamp
lamp is busted, better check your date of purchase for warranty.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Jan 26, 2008 | Epson Stylus CX7800 Color Flatbed...
Dell E173FP 17" LCD Monitor Logo
Alun Cox
