Question about Dryers
Kenmore Series 80 (model 110.74812200); dryer does not always heat up when on. When it does heat up it seems to stop producing heat before the proper temperature is reached
I have the problem.i have replaced the thermal cut off sw. and cycle thermostat next will be the flame sensor.(mntd.on the side of burner duct)remove the plug off the left front and you can watch the burner cycle - havnt figured out how to get to it?
Ben
Posted on Dec 08, 2008
SOURCE:
Kenmore series 80 heats and turns fine but stops after 30 minutes or so at any heat setting
Does it restart after it cools down? If so your motor may be overheating and shutting down.
Jun 20, 2012 | Kenmore series 70 80 90 Dryer Motor...
10 year old Kenmore dryer Series 80 suddenly has stopped producing heat. Vent is clean. What else can I try?
On a gas model dryer those coils seem to die when heated when they have a little age on em. So if the ignitor works and the dryer does a little bit of heating then fails and it is gas then those coils are the problem. On an electric model the element will get brittle with age and die but if your dryer is suffering from air restrictions it may have had a limit trip on it.
I have a service manual and more of a Kenmore /whirlpool style dryer HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 18, 2011 | Dryers
Dryer not producing heat
Check thermostat/ Element....See also if has scut out @ back casing reset
Oct 08, 2009 | Dryers
Kenmore 80 series quit heating after burning smell..
Any kind of lint or cobwebs on the element would cause a hot spot and fry the element or pop the limit that is mounted on top of the chamber. What your hubby soulda done is take the machine down and vacuum it out after sitting up so long. The fuse is not blown because it still runs so it must be the small guy pictured. It mount up top of the heat element chamber.ff8b5e7.jpg
Dec 22, 2008 | Dryers
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore 80 series stop turning
most likely a bad motor; expensive.
May 19, 2008 | Kenmore 63942 Dryer
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
293 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
