Question about Linksys Wireless-G WRT54G Router
Linksys can't find ip address
Wireless connection status keeps reading acquiring network address doing the repair doesn't seem to fix it
  • Anonymous Aug 16, 2008
    can't find ip address on laptop
  • rexical Dec 20, 2008
    i have linksis wrt54g router and a wireless network card wmp54g on a computer. not sure why the computer has such a big problem getting the ip of the router and i have to repair the connection many times before it connects. is it a conflict with the motherboard? i have formated and changed operating system and the problem still occurs. very very frustrating!
    Scholar:
  • 93 Answers
TCP/IP stack repair options for use with Windows XP with SP2 & Vista.
For XP, Start, Run, CMD to open a command prompt.
For Vista, Start, Programs\Accessories and right click on Command Prompt, select "Run as Administrator" to open a command prompt.
Reset WINSOCK entries to installation defaults: netsh winsock reset catalog
Reset TCP/IP stack to installation defaults. netsh int ip reset reset.log
Reboot the machine.
Posted on Aug 14, 2008
  • 3 Answers
Try to make "full" restart to wireless router. Hold reset button down 8 seconds (It is delete all your settings). Then connect to your router with default IP (192.168.1.1).
Posted on Dec 21, 2008
The wap54G is having issues. Computers trying to connect to it keep acquiring ip address and never connecting. Any advice on what might be wrong?
Hi williamrayes,
If you have a message that acquiring ip address you can Power Cycle the router for 2 minutes then try to connect again or you can try to check if the Network Key that your typing is correct (If the connection is secured). You can check the Network Key of your router by accessing the Wireless Settings Page of your router. To access the router page just open a browser then type 192.168.1.1, the Default username is blank and the password is admin. Go to the Wireless Tab select Wireless Security, You can personalize the Network Key if your want. Save the settings then try to connect.
Rate me if this helps so I can help others.
Thanks for using Fixya.
Feb 04, 2011 | Linksys Wireless-G WAP54G 802.11g/b...
Says i am connected but when i open firefox it says that i have no network connection... the wireless icon also says it is acquiring ip address
if the message aquiring ip address comes in computer then it says that the wireless router is not giving an ip address to your computer.... check if any static ip address is assigned to your wireless connection...if so change to "obtain ip address automatically".... right click on wireless network name> goto properties > authentication tab> uncheck "enable IEE athentication"
now try to connect again,still not restart the computer once...... this will resolve the issue.... still if it is not connected then check for the security settings in the router... if your computer is XP/MAC, it may not recognize WPA security type.... change it to WEP type and try to connect again....
Apr 19, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys WRT54GX4 loses internet connection
Not a problem, you have to consider maybe other devices and or networks competing/interferring with your network. If you know how to enter the Linksys router menu I would 1. change the frequency the router operates on 2. change the channel the router will use 3. change the default password to something else besides the default.
All of the settings for your router out of the box are at default, wonder how many other people are running the same thing in your neighborhood? I always change from the default, you may also be receiving interference from devices using the same freq/channel as your router. Changing these will eliminate those possibilities.
Don't forget to encrypt your network, that is most important.
Jul 15, 2009 | Linksys WRT54GX4 WIRELESS 802.11G...
My WL-138G cards loose connection info when shutdown
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 27, 2009 | ASUS WL-138G Wireless Adapter
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Wireless printer gets ip address different from my routers ip add
Check on the wireless network the printer is connecting to. Make sure it is your router.
Feb 03, 2009 | Lexmark X4650 InkJet Printer
Acquiring Network Address
reset the modem and the wireless router by powering them off for 30-60 seconds, then plug power back in. Wait a minute or so for the devices to reset then go to the PC and try to connect again
Good luck
Jan 26, 2009 | Dell Inspiron 2200 Notebook
I am trying to connect to the wireless in my new apartment. I have entered my network and password and that has worked fine. However, under Wireless Network Connection Status (i can get there by clicking...
On the Support tab - what does it say the "Address Type" ?
If its DHCP then check that on the TCP/IP properties;
If on "automatic IP address" then it wont take any entered IP address.
Do not put any IP address.
Check that "Obtain an IP address automatically" is checked and also "Obtain DNS server address automatically" is also checked. On wireless network tab check "Use Windows to configure my wireless network settings".
On preferred network check that your wireless network is there, if not add it and move it up
Netgear wg111v2 wireless usb adapter wont acquire ip address
Not sure if this is where you are looking, but it probably is. click START then CONNECT TO then SHOW ALL CONNECTIONS then right click LOCAL AREA CONNECTION click STATUS then SUPPORT,,,
or CONTROL PANEL then NETWORK CONNECTIONS then right click LOCAL AREA CONNECTIONS then click STATUS then SUPPORT tab
See what you have there for an IP address
Is it the computer you don't have an IP for or the router? In my case my computer IP the 8th or last digit is the next number after what it is for the router. The other numbers are the same
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Having Problem Acquiring IP Address
when using the range extender you have to make sure you set the SSID, channel & wireless key in the range extender the exact same as the router also it has to be in the same IP range so if the router IP address is 192.168.0.1 the range extender IP address has to change from 192.168.1.240 to 19.168.0.240. Hope that helps.
Dec 25, 2007 | Linksys Wireless-G Range Expander (WRE54G)
Linksys Wireless-G WRT54G Router Logo
1,047 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
