Question about Bosch Dishwashers
Spots on glasses; soap debris stuck in water jets
  • 38 Answers
Switch to a liquid detergent, clean screens and jets, add rinse aid, and remove large food soil from wares before placing into dish washer.
Hope this helps,
Kermit.
Posted on Aug 19, 2008
Dishwasher won't drain
You may need to clean out the trap below the dish rack in the bottom of the machine. Remove any debris that may be in the floor of the washer. For a Frigidaire, I know you push down and turn the trap clockwise until it releases; remove the trap by pulling up on the water jet; remove the glass trap and empty, then clean any debris below or around the trap; replace the glass trap, replace the water jet, turn counter-clockwise until it clicks; replace the dish rack. Be sure to use mild cleanser, such as dish soap or vinegar--no harsh chemicals as they will damage the machine. Good Luck!
Oct 03, 2017 | Dishwashers
Dishes and glasses are stained. Silverware is spotty, I've checked water pressure and temperature and they are within spec. Soap dispenser and jet-dry compartments are filled as per owner's...
Add glass Magic or Lemon Shine to the soap in the door for every load, this will impress you. You will not have to rewash again. It only takes 2 tablespoon on top of the soap in the door.
I find Lemon Shine at Target, under four dollars and works great.
You have nothing to loose.....
You can smile again..
Aug 30, 2011 | KitchenAid Dishwashers
My glasses & silverwear have streaks & spots on them. I have a water softener & don't use jetdry since we were told that would be the cause of the streaking/spotting. I have new glasses &...
First off whoever told you jet dry causes streaks has not been repairing dishwasher like I have for the last 40 years. All I will say is use the Jet Dry even with a water softener. Buy the little hanging mini-basket type ones and replace them as they are consumed.
Water flow problems are what cause streaks. The water flow problems can be caused by several things:
1. Clogged spray arm holes (Clean wash arms)
2. Sump inlets that are blocked with debris or plastic (Clean inlets)
3. POOR DRAIN FUNCTION ( a. Inspect all parts of the drain going backward from the sink connection
1) The sink connection is uaually at the side of garbage disposal. Remove the hose from the sink connection and clean out the port.
2) The AIR-GAP is the where 75% of the drain restrictions mainfest. Lift off the Air-Gap cover then unscrew the inner cap nut NOTING the installed position of the inner cap because you can only install it ONE WAY. Lift off the cap and remove an debris inside. Use a flashlight and inspect for any debris deep inside the Air Gap,
3) Inspect the Drain hose from the Air Gap to the Dishwasher drain hose connection for any kinks or folds. If you note wither a kink or a fold take a stick over the outside of the hose like you were putting on a splint.
4) Remove the drain hose from the dishwasher connection and inspect for debris. Clean as necessary. Just note there is power under the dishwasher that can reach out and grab you so make sure the power is off before working under the dishwasher.
Reassemble everything power it up, use the Jet Dry and let me know how the dishes turn out.
Thanks for choosing FixYa,
Kelly
Mar 31, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
Apr 04, 2010 | Maytag MDB9600A Jetclean II Built-in...
The door is always wet on the inside. I use the heated drying cycle. Glasses don't always come clean, are spotted, and the silverware is still wet. We have a water softner so that is not causing the...
1.you must fill your dispenser with jet dry.2. make swure water is hot going into maching from faucet then start machine. 3.add cascade soap. you will see a big difference. im a old bosch tech:) let me know what happens .
Feb 25, 2010 | Dishwashers
My glasses arecoming out with soap and water spots. I think the dishwashing soap has clogged up the washer/ sprayer arms. is there any cleaning solvant (eg CLR) I can use to clean out the washer
add rinse aid to rinse aid dispenser... that should help the spots.. as for cleaning the arms.. not really necessary... but you should pull them off occasionally and see if there is something stuck in the holes... i found rice in mine.
Dec 05, 2009 | Sewing Machines
Blue sticky spots in my dishwasher
some of the soaps out there are tempurture sensitive, several different ingrediants waiting on different temps during differnet times of the cycle,
I have seen this before or at least something similar,
does the soap your using now have the jet dry as part of it
if yes id go back to jet dry, your rinse cycle is not hot enough to fully disolve the jet dry in the soap, it gels and coaleses every where.
its designed to do that, so it will not just be washed down the drain on the wash cyle with the rest of the soap.....
Oct 11, 2009 | Dishwashers
The dishes come out dirtier after they're "washed"! The soap leaves a filmy residue and I have to re-wash all the dishes. I've tried liquid Cascade, the Finish tablets, and putting Jet Dry rinse aid in...
Take out the botton dish rack and check the drain. Most likely there is a screen that is supposed to catch big debris and keep it from entering the drain. It's probably got a lot of gunck in it. Take the screen out and clean it and check under the screen too!
Jul 29, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Glasses do not get cleaned
HI, i recommend inspecting these areas below to combat this issue.
Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 18, 2009 | Maytag Dishwashers
Dishes not cleaned
When ever I hear of a dishwasher "suddenly" not cleaning properly, with spots on the glassware and soap not dissolving:
-If the spots are white patches, you can suspect the DW detergent powder. Go buy a name brand of detergent powder and I bet you will see a dramatic improvement. You may need to run a cycle or two with white vinegar added (up to two cups added after the DW starts, fills and begins to wash.)
-If the spots are a film / slime, you should suspect that the heating element. For the dW to be effective cleaning and rinsing clear,the DW needs to raise the water temp during the ~wash~ cycle (after the detergent dispenser has magically opened. After the heating element has been replaced, you will see an immediate improvement.
-If you had reported food debris sticking to dishes, (which you didn't), the first thing to do is clear the holes in the wash arms, then open the sump area , remove the filter assembly and inspect closely with a flashlight to locate blocking debris. (watch out for broken glass!) Inspect the impeller and make sure it is not damaged. If after assembly, the cleaning is still poor, it is time to replace the wash pump / motor assembly.
Good Luck! Ask more questions as needed!
Mar 30, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
101 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
