Question about Hotpoint First Edition FEW12 Front Load Washer
Washer door won't open (hotpoint first editon 800)
The washer door won't open. (hotpoint first edition 800)i have turned on the washer after 10 seconds of a doing a cycle the fuse in the plug had blown. We then replaced the fuse in the plug, the washer continued and completed the cycle but the door lock light is still lit and the door will not open. We have put the same wash through another cycle and the door is still locked.
Can Anyone help with this. without having to call out an engineer.
  • ditomiranda Nov 30, 2009
    hi, same problem here, fuse... rest of the wash... not opening. I took the top cover of the washing machine off and then i slid my hand to the orange door look inside, had to be careful cuz of cables and electric bits around the top, once your fingers get there you should be able to open the hatch by pressing a little sort of button there, try to open with the other hand, i doesnt need much force on it, it is a very small and simple mechanism. Of course on my next wash i realized that i doesn't open again so have to do the whole hand in the hole procedure again. Now i just need to know what exactly do i need to fix or replace for this not to happen again, will it be the door mechanism? or a fuse of some sort somewhere? help! Can't live opening the bloody top of the machine every time! (the thing is fitted under my kitchen work tops)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Posted on Aug 20, 2008
Where is pressure chamber bottli in hotpoint first editon 1000 wm19?
to get to it you need to remove the plug so there is no power to the machine????
take off the top
turn upside down ,
put the screws into the lid as you take them out
remove the dial screw at the back
remove soap dish.. 6 screws
unclip the door seal
take of the front 6 screws
follow the pipe from pressure switch down
there it is to take of and clean there is 3 screws
now you need a dumpy screw driver
May 18, 2014 | Hotpoint First Edition FEW12 Front Load...
Door will not open
On a Hotpoint front loader m/c, take the lower panel off at floor level. Try not to break it as fragile. To the right is an emergency tab, pull on the tab downwards at the same time as using the door handle. It should now open.
Apr 03, 2010 | Hotpoint First Edition WMA12 Front Load...
Hotpoint electronic 800 delux 9525. can not open the door help
Make sure there is no water left inside washer.
If it still will not open, then you need to remove the top cover, and release the door manually from inside at the front where the door latches in.
Can be caused by the belt being off the pulley,or a broken ****** assy.
Jan 12, 2010 | Hotpoint Washing Machines
Washer wont start hotpoint first edition 800, WM51
If you have established that the washer is getting power, then I would suspect that the door interlock is the cause of the trouble., try fitting a new one.
Please rate my solution.
Nov 04, 2009 | Hotpoint Dryers
Hotpoint WM51 Washing Machine keeps tripping the electric
Ok that rules out the heating element. There are a number of possible causes so bear with me while i go through them.
Can you open the door? If so leave it open then turn on the machine. Does it trip?
Jan 23, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint 800 wm 11 goes through cycle but won't spill or drain
hi there maybe your waste pipe might be blocked from washing machine or mqaybe there is a blockage somewhere else in your plumbing which does happen queit alot? hope this helps
Jan 11, 2009 | Hotpoint First Edition FEW12 Front Load...
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Door of washing machine will not open.
Some times, you have to really pull hard to open the door
If no joy, then you have a faulty door lock.
To replace. remove door seal at front, thius will give you access to the door lock.
Nov 18, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
610 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
