Will not spin clothes dry! Kenmore Elite SM 9711174 heavy duty top load king size capacity ultra quiet pak II
This top load washer does not seem to have any get up and go.
It will not spin in the spin cycle. A little push on the drum and it will start a bit but no real get up and go. We have also had to watch for the rinse cycle and the fabric softener dispenser does not do it any longer.
Also makes a very loud banging noise sometimes on and off.
Noise only lasts about 20 seconds and stops.
Leaves clothes sopping wet.
  • 1 more comment
  • Anonymous Dec 17, 2008
    I have the same problem.
  • ercarter Mar 25, 2009
    Noisy at beginning of a spin. Not quite able to get rid of water like it used to. Seems to be the spin transmission is faulty. Tilted over to see if there was a belt - no belt that I can see - so this to me means it's likely time to replace.
  • rhondakenney May 11, 2010
kjmac
  • 97 Answers
SOURCE: Dispenser still full of water and fabric softener
hiya
this could be caused by a faulty cold inlet valve if the detergent is not being taken away. however if the detergent iis being taken away then the valve is working ok as it fills the compartment with water lifting the detergent out and into the washing machine.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 03, 2008
  • 12 Answers
SOURCE: my bosch classixx 1000 express wont take the fabric softener
take out the soap drawer and clean it there will b a blockage in the softener nozzle this will clear the problem
Posted on Dec 21, 2008
  • 220 Answers
SOURCE: fabric softener dispenser won't drain the fabric softener.
Not sure if you already did this, but try pulling the face plates off inside the dispencer and take it to the sink and run very hot water into the "stand pipe" that projects off the back of the face plate to make sure they are clear and no old crusty products are in the hole.. Then put them back in and push down hard and make sure they are fully seated.
If the plates are loose and not seated or clogged, there will be little or no siphon effect to draw the fluids out of the dispenser. At least thats how it seems to work
Also, if you pull the top off the washer, there is an adjustment on top of the dispenser to adjust the dispensing ratios I believe.
I just did that procedure the other day on my machine and the wife said it works good now.
Let me know it it works for you, I was wondering if it was just a coincidence.
Posted on Jan 16, 2009
blueextc3221
  • 15935 Answers
It appears your softener tray door solenoid has failed in this instance... or it may be gummed up.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
tiger56h
  • 176 Answers
SOURCE: Kenmore 90 series Heavy Duty Super Capacity Plus
hi check the lid swetch
Posted on Sep 15, 2010
Motor on kenmore elite washer quiet pak ii heavy duty capacity king size wont engage, just hums. and ideas?
Sounds like you motor coupling is gone this happens when over fill washer or place carpets/ bed blankets
Feb 15, 2015 | Kenmore Washing Machines
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Oct 30, 2006 | Kenmore 15944 Top Load Washer
Washine Machine
-Sounds like the timer is out. Check it out and replace it
Good luck
Mai
May 16, 2017 | Kenmore 22642 Top Load Washer
Washing Machines Logo
1,362 people viewed this question
Top Washing Machines Experts
