Question about Dell 924 All-in-One InkJet Printer
Paper Will Not Feed Through
When I try to print the paper is pulled about a quarter of the way down and then does not move. I have tried fanning through the paper to make sure it does not stick together and I have tried different types of paper but nothing has helped.
  • 2 more comments
  • Anonymous Aug 19, 2008
    I had a similar problem with the Dell All-in-One 966 InkJet printer. When I make a copy, the paper feeds. Whenever I try to print, the paper jams. I called support and they kept asking me questions about the paper, tray, and things that I knew were ok because the paper could feed to copy. Finally, they said they would ship a new printer base unit.
  • Anonymous Aug 29, 2008
    I have the same problem...it will print sometimes and get stuck other times. Very aggravating. MAS
  • tayo_uni_net Mar 17, 2009
    Dell 948 A-I-O Paper Jam with continiuos Clear Paper Jam error. Recently had a problem with the paper feed, where abulk of paper was sucked but got stuck in the machine's paper feedmidway.
    After removingthe bulk-paper, I have not been able to usethe printer as italwaysdisplays the ''Clear paper jam , then press...''error even whenthereis no paper in any part of the printer.
    Havetried putting theprinter off and on again but no luck...the printersalways makes itsnormal start up sounds followed by a remarkablewheel-spinningnoise andthen goes to display the error signal.
    Please advice on this.
    Thanks
    TYKool
  • melvinlwoods Apr 24, 2009
    how do you open the cover to get inside the dell printer. i have a ball stuck inside
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Lets try few troubleshooting for paper Jam issue.
Locate and Remove Any Obstructions Inside the Printer and Input Tray
1. Open the front cover and make sure the kickstand (if there is one) is engaged.
2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
3. Close the cover.
4. Remove all paper from the input tray.
5. Inspect the input tray for any obstructions.
6. Remove any visible obstructions.
7. Reinsert the paper.
Adjust the Printer Paper Guides
Extend the front paper support on the printer.
Try a Different Piece of Paper in the Printer
1. Take the top 10 sheets off of the **** of paper.
2. Verify that the remaining sheets of the **** are not wrinkled or dirty.
3. Replace the remaining part of the **** back in the printer.
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Try a Different Type of Print Media
Many image quality and paper feed issues are caused by the type of print media being used.
Try a different type of print media that is specifically made for this printer.
When there is no different print media available, take out the top half of the stack and flip it over.
Try holding the printer upside down and shake it moderately
Make sure you remove all the cables from printer before performing it
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Posted on Nov 07, 2008
Canon mp280
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
May 13, 2013 | Canon Office Equipment & Supplies
Printer problem
May 12, 2013 | Canon MX300 Office All-In-One Printer
When we try to print keeps saying load paper even although there is paper in feed tray. We have tried removing and replacing apper still same problem Printer just does not seem to register that there is...
Good Luck!!!!!
Sep 24, 2011 | Lexmark X4530 InkJet Printer
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
My printer is feeding more than one page at a time my printer is cannon 3000
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If it still fails to feed the paper correctly, please reply with the following information:
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results?
May 23, 2009 | Office Equipment & Supplies
Epson CX5000 Paper will not load. Tries to but says paper jam even when there is no paper jammed. Blank pages will go through during reset but not otherwise.
What type and brand of paper were you using? Have you ever used this type or brand of paper before and if so what were the results? Once we have this information we will try to fix the unit through email support.
Apr 29, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Printer grabes paper at an angle every time i try to print a page,never has done this before, am using same kind of paper, just keep's going in sidways,thank's rr
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let me know.
Apr 18, 2009 | Lexmark X1270 All-In-One InkJet Printer
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
hi...
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
124 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
