Question about Frigidaire GLTR1670A Front Load Washer
Door lock the door lock light is on and will not go off and i can't open the door to start a wash. but i can change the cycles and all that stuff.
    Novelist:
  • 166 Answers
Peace Friend,
ngafm At your service!
This is like n error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Posted on Sep 05, 2008
SOURCE:
How do you get the child lock off on a Haier dishwasher?
Just consult the manual. :>)
English
Changing the Wash Program / Cycle:
If at any time during the washing process you would like to change the
selected wash program /cycle;
1. Press and hold the START / RESET button for approximately 3 seconds.
(The START / RESET indicator light will be ON indicating that the unit is
in PAUSE mode.)
2. Select the desired wash program / cycle by pressing the program
button.
3. Press the START / RESET button again, the dishwasher will resume
operation using the newly selected wash program / cycle.
NOTE: If you change the wash program / cycle after the detergent
has been dispensed or the dishwasher has already drained the
water, you will need to refill the detergent dispenser for the newly
selected program / cycle accordingly.
At the End of the Wash Cycle Once the dishwasher has completed the selected wash cycle / program,
there will be a buzzer sound for 8 seconds indicating the end of the cycle.
1. Shut off the water supply.
2. Turn the dishwasher OFF by pressing the ON/OFF button.
3. Open the door slightly with caution to allow any residual steam to
escape.
4. Wait a few minutes (approximately 15 minutes) before unloading the
dishwasher as the dishes and cutlery will be hot. This also aids in the
drying process.
5. The interior of the dishwasher will be wet, this is normal and will dry
naturally.
WARNING: It is dangerous to open the door when dishwasher in
Checking the Water Temperature
For the most effective cleaning and to prevent damage to the dishes being
cleaned, the water supplied to the dishwasher should be at a temperature
of at least 120?F (49?C) and no more than 150?F (66?C).
Child Lock Function
The child lock function will prevent the unit from functioning and the door from being able to open if it is in the fully closed position.
To engage the function, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will illuminate in the display when the child lock function is activated.
To disengage, press the "3-in-1" button and the "Delay" button at the same time. The "lock" icon will go off in the display when the child lock function is deactivated.
Haier HDC2406TW User Manual At The End Of The Wash Cycle Child Lock...
Jan 31, 2017 | Haier Dishwashers
Washing machine Hotpoint Aquarius WMF740
Its normal for the door not to open with water in the machine this is a safety feature the door will not open immediately after the wash cycle completes their is a delay before it can be opened.
May 04, 2015 | Washing Machines
Why does my Maytag Neptune washer door stays locked after cycle is complete.
sounds like the locker servo is having an issue there and may need replacement contact Maytag for a replacement part
Aug 22, 2017 | Washing Machines
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Control locked light is on.Can not start the cycle.
Open and close the door. The door has to be opened between consecutive wash cycles.
2. Check the door switch 3. If Door is Locked, Drain the Unit. 4. Check the wire harness connections. 5. Check the touch-pad/LED assembly.
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a bosch washer model wfk2401. i cannot get
door lock mechanism must have jammed in open position. unless the door gets locked, the wash cycle would not start. check the electrical connection in the door lock and physically verify the lock operates when commanded
Mar 19, 2010 | Washing Machines
Wash cycle will not start
the door interlock is faulty, hit the door handle area with the palm of your hand, make sure machine is turned off 5 mins before hand. Replace door lock IRE bye.PS it should open when you hit it bye again. remember the palm of your hand
Nov 02, 2007 | Whirlpool GHW9200L Front Load Washer
Washer door pops open during wash cycle
Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
Frigidaire GLTR1670A Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
