My 3m transparency maker has just stopped working. The little red switch that will trip was not tripped.
  • Anonymous Mar 23, 2009
    i am having the same issue with the exact same machine 45cg..runs good but entire paper is dark...usually with no stencil at all...any suggestions...please
    thanks
    kenny
  • Anonymous Apr 22, 2009
    lamp stays on after copy exits
Whole carbon paper is dark cant lightin up.3m thermo fax 45 cg
jmanstattoos@yahoo.com
3372502737
john ohlemacher
Posted on Nov 09, 2008
Why does the trip switch keep coming on the ryobi mulch maker rjs1500?
You either have a bad unit that is drawing too much amperage or the unit requires more amps than the current circuit breaker allows.
May 06, 2014 | Coffee Makers & Espresso Machines
Trips safety switch
Might be best to call the manufacturer or a licensed repaire to avoid voiding your warranty?
Jan 09, 2014 | Washing Machines
The water will not heat
One of the most common things that causes the Sylvia to stop heating is a tripped thermal reset. Unplug the unit and remove the top panel screws. Underneath the panel you will see the boiler. On the top of the boiler you will see a couple of different round devices with a wire going to each side. Look for the one that has a little red button on top. Press it and listen for a click. If it clicks you fixed it. If it trips again after its been running for a while it means that the boiler is overheating and you probably need to get the thermostats replaced (the other two circle things). Good luck, I hope it helps - mike@espressomachineexperts.com
Dec 17, 2010 | Rancilio Silvia Espresso Machine
As soon as i switch on the power the power is tripped
What exactly is tripping out? Most kitchens now have GFI recepticals. There is a small red button that pops out if the circuit detects moisture inside the electrical parts of the coffee maker. If that is tripping you may be able to simply dry out the coffee maker by turning it upside down and then blowing the switch and electronic controls with a hair dryer for a few minutes. Try the coffee maker is a receptical in the bedroom. If it doesn't trip there it is probably moisture caused by spilling a little water on the machine when you were filling it. If it trips the bedroom breaker, it is most likely a dead short in the machine. Normally it is not worth the labor and parts to repair this machine.
Sep 13, 2010 | Keurig B100 Coffee Maker
Thermofax machine repair
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
Mar 30, 2009 | Office Equipment & Supplies
My 3m transparency maker was dropped. runs but makes no copies
this post is for projectors. try other office equipment.
Mar 27, 2009 | Office Equipment & Supplies
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Dryer tripping electricity saftey switch
You probably have a shorted heating element.
May 15, 2007 | Miele T1322C Electric Dryer
873 people viewed this question
jasbo
jasbo
