Question about IBM ThinkPad T21 Notebook
Gateway Laptop The A/C adapter for this laptop went dead, I purchased another and in two weeks it died but before it did I could get it to charge by pulling the connector out of the back of the laptop a little and it would charge, but after a few times this stopped also. So I went and bought a universal adapter and tryed it without the battery because I thought maybe the battery was causing the A/C adapter to short out. Even with the univeral adapter the laptop would not power up. I stuck the battery back in with the A/C adapter also plugged in and when I hit the start button I got a red led light where it normally shows that the battery is charging. Could you help?
    Genius:
  • 2,028 Answers
This sounds like a loose or broken jack. Check the jack on the machine, use a small screw driver, and see if it has any play. This could potentially cause serious damage to the machine, if it hasn't already. If the jack is loose or broken, then you will need to have it replaced. If you cannot tell whether is loose/broken, then I suggest that you take it in for a professional diagnosis, they will be able to tell you if the jack is broken, if it has done more serious damage, and where the problem area is exactly. By the sounds of it, I'm going to say that some damage has already been done, let's just hope it's not too serious.
Posted on Aug 13, 2008
Dell inspiron not charging
Dear Mathew,
You should you Dell Utility and it has the function called Dell Battery Metter, it can enable or disable charging
Nov 12, 2012 | Computers & Internet
My laptop not charging
When you say it won't charge, does it charge at all?
1. It indicates that it is charging, but as soon as you unplug the charger the battery quickly or immediately indicates it is dead. If the laptop is off, the LED on the laptop shows it is charging but the battery is always dead,
Or: 2. It is as if you didn't have the charger plugged in. No light on the laptop at all when the charger is plugged in.
Possible solutions:
1. The battery has died and is no longer capable of taking a charge. An alternate explanation if you can't even get the laptop to turn on even though the laptop charge LED is on, is that the internal power supply that converts the incoming and battery voltage to all the voltages required has died.
Or: 2. The power connector inside the laptop is a common failure point. The solder joints break from various minor shocks over time. This is going to become more common with lead-free solder as it is more brittle. Less likely is that the charging circuit inside the laptop has failed.
http://www.chargerbuy.com/laptop-ac-adapter/universal-ac-adapters.html
Oct 28, 2012 | Computers & Internet
I purchased a new adapter and my laptop will still not charge and work.
Try taking out the battery and leaving the adapter in without the battery. If that laptop powers on then try to put the battery back. It is most likely an issue with the motherboard.
Feb 24, 2011 | Gateway MX6124 Laptop AC Power Adapter...
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
WAS MISSING CHARGER, but was running on battery. will not charge battery or power up, no lights. Battery went dead MT6821 GATEWAY
All you need to do is be sure whu will need to replace both.
If the problem is with either the charger/battery you will need to figure that out first.
Please have the battery charged of your laptop, and try using the laptop only with the battery and without the charger, If it works fine you will have to check the charger now.
In order to check the charger, please take out the battery from the laptop, now connect your charger to the laptop and try switching on the laptop. If it does not work then your charger is faulty.
You can purchase the accessories online at various portals. I am providing one of the portal information:
http://www.laptoptraveller.com/battery-gateway-mt6821-laptop-notebook-accessories.html
Sep 01, 2010 | Gateway Computers & Internet
Dell Latitude D600 won't power on w/ or w/out power adapter
the problem is really mysterious. because in most of cases the battery is the villain. and when it is replaced the issue should be over. there are no other components of a laptop which is directly or indirectly related with battery perfomance.
any way get back me with more details like the age of system and number of times taken to service center etc etc @ deepuunni1985@gmail.com
Aug 22, 2009 | Dell Latitude D600 Notebook
All the lights of my gateway MT3418 are on, but screen is black
Can you see a background image when get really close to the screen?
Cheers
Sep 24, 2008 | Gateway MT3418 Notebook
Battery won't charge.
battery could be dead,standard life for laptops is 1 year
Jun 26, 2008 | Gateway 450ROG Notebook
CHARGER
I assume by charge you mean your power adapter. If this is the case you can purchase any universal power adapter for laptops within an acceptable wattage for your laptop computer. You can either visit your local best buy or circuit city store or purchase one at newegg.com. http://www.newegg.com/Product/Product.aspx?Item=N82E16834999586&Tpk=N82E16834999586 Hope this helps. :)
Oct 05, 2007 | Gateway M305CRV Notebook
IBM ThinkPad T21 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
