Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer switch fill washer ??
Now  when I try to turn the dryer on the tub fills with water as long as I hold the dryer "on" switch ?? CRAZY !! The dryer does not operate during this time. Any help would be appreciated.
Tom
  • murrell_t Aug 24, 2008
    After talking to the owner of a appliance repair parts storm I took the top off the dryer drum looking for a short in the coil. I didn't find one but when we put the machine back together again it worked. GHOSTS or ???
    Thanks for your advise.
    Tom
  • 639 Answers
Sounds like an Electronic problem.
You should call service.
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
Try :
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a solution solved rating in this site
Thank You
Neil
Posted on Aug 24, 2008
Washer wont stop filling up what does part look like i have anohter washer take part from
Well, I think I may have an easy answer. There is an atmospheric switch. There is a tube within the tub, but on the outside of the area for washing clothes it goes down to the bottom, or nearly so, and when you fill the tub with with water, the water will then when filling, push the air in the tube up to the switch telling it when to stop. Its probably clogged and you need to pop the top of the washer to find it.
Apr 13, 2016 | Whirlpool Thin Twin Washer and Electric...
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Won't fill with water and goes right to wash cycle
Chech the pressure lelvel switch and hose that is connect to the pressure switch and tub
Mar 25, 2010 | Frigidaire FEX831CS Top Load Stacked...
Washer Won't Fill, New fill Valve, makes humming noise
Check your water level switch it may be showing full. If it is it won't fill. If you can set it on spin and run for 2 or 3 min. it might clear the hose from the tub to the switch in case there is too much water in it. Or you could pull the hose off the switch and blow in it to be sure it is clear. Sometime if it gets too much in it it builds up too much pressure and shows full.
Jun 09, 2009 | Washing Machines
Washer will not stop filling up it overflows
Very simple. No parts needed! Remove the pressure tube that connects from the water level switch down to th bottom of the tub. Blow out the trash that has accumulated in the bottom of the tub and re connect the tube to the water level switch. Drain the washer. Retry.a097efc.jpg
Dec 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Continuously fills with water
I'd suspect that the water level switch was malfunctioning. It's easily checked once the top of the washer has been removed. There is a tube running up to it from the tub. Water going up the tube changes the pressure on that switch and it reacts, opening to shut down the fill valves.
Doug
Jun 09, 2008 | Equator EZ 3612 CEE Front Load...
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
51 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
