I had the same problem reattaching the 46" deck on my Cub Cadet Lt1045 lawn tractor. The instructions for removal are not reversible for reattachment. The following instructions for reattaching the deck are not found in the manual and not on line either as far as I can tell.
Step 1. Remove the pins with cotter pins that hold the U shaped bar that supports the front of the deck allowing the removal of this bar.
Step 2. With the deck below the mower and the lever on the left fender in the lowest position, align vertically the deck rear pin holes with the holes in the arms used top raise and lower the deck. Move these arms down until the holes line up and run the spring loaded pins into the holes.
Step 3. Put the U shaped bar into the slots on the front of the deck and pull it forward and secure it to the front of the mower by reinstalling the pins and cotter pins the same way it was before you removed it.
Step 4. Re-install the deck belt onto the engine pulley according to other instructions found in FixYa. And you're done.
Http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02100.pdf
