Hi I have a 50HX81 Toshiba Cinema Series rear projection TV. About three weeks ago mid way thru watching a show, the left lower quadrant messed up. The colors were seperated in an arch. The greens were like an arch. The rest were ok. I tried the 56 convergence correction, but in vain. One could clearly see the green out in an arch and wouldnot correct. Now the top two corners are also distorted, the green are curved upwards like horns. Could someone help in advicing what the solution to this problem could be. Also if it is the convergence board, what part number and what would it look like. What might be the possible fixing cost if I had to call a service tech? Appreciate any help out there. AKR
  • 3,037 Answers
A refection mirror may be knocked off or have something spilled on it (possibly a leak) from the tv
Posted on Aug 13, 2008
    Master:
  • 521 Answers
The STK ic on your board requires replacement . if you call a technical person to get it done it wont cost you much. you can say just a bit more than the service charge. calling a technician is the best option i can suggest. thanks
  • tech expert12 Aug 13, 2008
    pls do rate the solution
I HAVE 2000 TOSHIBA 50" CINEMA SERIES MODEL 61HX70. WHEN I TRY TO TURN IT ON, IT DOESN'T WORK, BUT THE RED LIGHT FLASHES CONTINUOUSLY. WHAT CAN I DO?
U have tools lilke a soldering iron,solder,desoldering pump or soldering wick?U know how to do basic soldering?Try website like Tvrepairworld.com to buy a capacitors kit,to fix the DM power supply board,will fix this problems.
Sep 09, 2010 | Toshiba 50HX81 50" Rear Projection...
Toshiba 50HX81 only showing black and white
I bet it's a DLP TV correct?
This symptom would indicate that the color wheel has flown apart. Which results in a monochrome only image.
Color wheels are expensive and need to be replaced by a qualified service person.
Dec 26, 2009 | Toshiba 50HX81 50" Rear Projection...
Hundreds of Blue dots on model KDF60WF655 Grand Wega.
optical block about 900 unless you can get a good used one. thats a common problem with that model
Dec 06, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
Toshiba TV 50HX81
Check fuses on Power Supply board (F850, F851, F852) and all other fuses. Replace blown fuses (will need an ohm meter to check fuses). I would also replace the two convergence amps (STK392-110's on the signal board, the big black ICs on the two heat sinks). This worked for me.
Mar 30, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba TN61X81 HD Cinema Series Sound Problem
what type of connection did you use for your playstation 3 to your tv....
Aug 10, 2007 | Toshiba TN61X81 61" Rear Projection...
My TV will not come on but the power button blinks red!
Very interesting. I have a Toshiba 53 H71. Same issue. It occurred to me after a move.. No one has offered any help on it. Posted about a week ago. Guess no one knows anything about these TV's....
Sep 02, 2006 | Toshiba 50HX81 50" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
