Question about Zenith VCS442 VHS VCR
Auto Set Channels
After recently unplugging my VCR and turning it back on I have to reset my channels every day! I can only view channels 1 thru 25 and the rest are blank until I go to the menu and change the tuning band to CATV. I have to do this every day to get the other channels! Also at the same time I no longer get any sound on only 2 of my channels if watching thru the VCR. If the VCR is off the sound is just fine. What gives? Is my VCR possessed or just ready for the dumpster?
    Sergeant:
  • 291 Answers
1ST) see if the power is being turned off on the machine from the power source.Do you have a time screen? A screen that tells the time, is it blinking ? You could have a loose connection to the AC plug. Does the machine have a "back up" memory battery ?
2nd) Sound on only 2 channels thru VCR is a circuit problem.
Posted on Aug 16, 2008
How can I receive and record cable channels on my Sony SLV 750 vcr? The tuner only displays channels 1-99 on the vcr. Thank you.
I will be assuming you have analog cable TV service, no cable box. If you have a cable box, the instructions would be different.
There are many steps to properly setup your Sony VCR and they should ALL be setup to correctly record channels, however just to cover your question here....
Press MENU on the remote control for the VCR and you should see on your TV screen, the main menu options. Select TUNER PRESET. Press OK. Set Antenna/Cable to CABLE. Next Select AUTO-PRESET. Available channels will be scanned. This may take a few mins. so be patient. Channels could go up to 125. This should make available cable channels ready to record/view.
You can ADD or Delete a specific channel also if one is missed or undesired by selecting MANUAL SET.
Feb 11, 2011 | Sony SLV-798HF VHS VCR
I just need to know how to link up my Allegro DVD/VCR REMOTE CONTROL to my Phllips Magnavox Television.
TUNING This DVD+VCR is equipped with a frequency synthe- sized tuner capable of receiving up to 181 channels. These include VHF channels 2-13, UHF channels 14-69 and CATV channels 1-125. Auto Channel Programming 1. Choose the SOURCE SELECT option, then use b / B to select TUNER. Use b / B to switch among TUNER, LINE1, and LINE2. 2. Choose the AUTO CHANNEL SET option, then use b / B to find channels. • The tuner will automatically cycle through all available channels (TV/CATV) in the area and place them in the tuner's memory. •After the AUTO CHANNEL SET is complete, the TUNING menu will hide and return to the TV screen automatically. 3. Make sure the TUNING BAND is set appropriately (TV or CATV). • TV : If you are using a standard antenna to receive channels. •CATV : If you are using basic cable to receive channels.
Oct 15, 2010 | Allegro DVD/VCR ABV511
Quasar VV-1302: Cannot Program Cable Channels
If you let it autoprogram and all you get is channel 103. Move the TV back to the old connection and see if it autoprograms all the channels there. If that works ok then you have a problem with the cabe line that only has channel 103.
Nov 17, 2009 | Quasar VV-1302 13 in. TV/VCR Combo
Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Aug 15, 2009 | Panasonic Televison & Video
Recording from cable
L1 and L2 are different inputs on the VCR.If you have red, white and yellow input on the front of the VCR then when you put the VCR on L1 it should pick up a signal from the front.To get more channels on your vcr you want to do an autoprogram make sure the cable from the wall is plugged into the input in the back and go to the menu on the VCR and look for channel search or auto program and start the search.usually you can find this setting under something like SETUP, Programming,settings on the main menu of the VCR.You may have to search in the menu of the vcr for a little bit until you find it.Youll know when you got it when the channels automatically start scanning from 1-98.GOOD LUCK and rate me if this fixesya or is helpful.
Nov 16, 2007 | Lands Phones
Toshibe 36AFX61 36" TV
I uncovered the problem. The "analog tuner" seems to have gone bad. The part is $25 -$36. The set can still be used however. I just removed the coaxial cable from ANT 1 in the back of the TV (this is what I believe has become defective)which was going to a VCR. I then just used composite cables(red,white,yellow)to bring the signal directly to the TV from the cable box, rather than the VCR. All works however, will replace the defective part.
Sep 18, 2007 | Toshiba 36AFX61 36" TV
Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Sep 11, 2006 | Panasonic PV-M1349 Combo
Zenith VCS442 VHS VCR Logo
81 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
