Question about Smeg S20XMF.1 Stainless Steel Electric Single Oven
Smeg Oven SA 20 XMF
Can you describe the temp settings for me as my glass panel is not transparent. ie if at 6 o'clock, is that 200 degrees? What is 5 o'clock etc. Hope you can help!!
5 Suggested Answers
SOURCE: setting time etc
Contact these guys, they import Smeg products into the country and have manuals available online also. APPLICO GROUP LTD: Whiteware Importers 120 Captain Springs Rd Box 92900 Onehunga Auck Ph (09)574-1050 Fax (09)574-1051 email: reception@applico.co.nz http://www.applico.co.nz/
Posted on Jul 22, 2007
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
SOURCE: SMEG SA 398X
OK I have just moved into an apartment with this model (SA 398 X/1) and was searching for a user guide (no luck yet).
Anyhow my apartment was owned by a bachelor and it looks as though he hardly used the oven so everything's still intact.
I'm in Australia and these numbers are in Celsius so I hope they work for you.
From top Right (starting at the 2 o'clock position) the four numbers going clockwise downwards are:
50
90
120
160
Then from the left side (starting at 7 o'clock position) going clockwise upwards:
200
230
250 - with dots arching above the 250
Hope this helps -
Jane
Posted on Oct 05, 2008
SOURCE: smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Posted on Dec 08, 2008
barkencoa
  • 3463 Answers
SOURCE: smeg oven
Sounds like you need a new oven element fitting.
Smeg pyrolitic oven is setting an alarm off on clock after we set the required temp it will start to heat up then the alarm goes off if not quick enough to reset clock, it then locks the oven door
in cleaning a pyrolitic oven is suppose to lock the oven door , this is a safety feature due to fact that oven gets up much higher in temp than a normal oven , the heated air it produces if let out would flash burn anything in front of it to ashes (people,pets,rugs,etc.) the clock doubles as your display window to see what temp oven is at , there should be a clock selection to see current time of day even if oven is in use , and last but not least , it has a delay cleaning start feature , you can set it to come on and clean it's self , Id recommend not to use this feature for safety reasons (I don't think the mfg thought that feature out too much )
the door should remain locked till oven temp is below a preset minimum safe temp ,id not force it open for safety reasons
Sep 28, 2015 | Smeg Ovens
Smeg electric oven timer controls
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
Which of the five small buttons do I press to make the oven function? start
Ok! Until the clock is set the oven will not work, I will describe the 5 buttons as numbers from the left!
Press and hold the 3rd button for 2seconds, then press the 4th or 5th buttons to set the clock to the correct time, then press the 3rd button to set!
Jan 01, 2015 | Smeg Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Smeg gb-ie
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 12, 2013 | Smeg Ovens
Fan bake on smeg oven not heating ,mod SA 9066XS
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Feb 02, 2012 | Smeg Ovens
SMEG SA 398X
50
90
120
160
200
230
Hope this helps -
Jane
Jul 20, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Oven light always on, no heat
probably the clock not set properly - you have the oven on automatic. switch off at mains, wait 5 mins and set the clock according to the manual. if the over-temp stat has operated, the oven goes dead
May 05, 2007 | Smeg S351X/5 Electric Single Oven
Smeg S20XMF.1 Stainless Steel Electric Single Oven Logo
110 people viewed this question
Top Smeg Ovens Experts
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
