Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1988 sportster 1200-
The plug wire came off the rear cylinder about 1/4 mile from the house and when i reattached the bike ran rough- sounds like it;s missing, and wants to stall in 1st gear- plugs seem ok - changed them and did no good- nothing else seem to have come off or be loose - any suggenstion of what to look at .
Try swapping out the wires. just grab two wires off the old lady's car and give it a spin, if all is well put her wires back and buy you a new set. could be the coil tunneling. ohm meter may or may not show up a problem. stock dual fire coil should run 3 to 5 ohms. on the primary. if you have a single fire set up with two coils you could have damaged the electronics if you have them and the power transistor that drives the coil is shot.
Posted on Aug 14, 2008
I have a 2003 Harley Davidson 1200 sportster,
Cab or injected ?
If carb looks like an leak at the Oring manifold .Try to start and spray any carb cleaner to the manifold close to the cylinder ,.any change on idle would be an air leak!
Oct 06, 2014 | Harley Davidson Motorcycles
Why does my 1998 1200 sportsters rear pipe dont
Hi Anonymous, and the usual suspects are:
1. Plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discarged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
Good luck
Sep 10, 2013 | 2000 Harley Davidson XL 1200 S Sportster...
2005 Harley Davidson 1200 Custom Sportster Stalls at Lights and Stop Signs
4700 not a lot of miles. This motorcycle needs to run. It will be rough until you can get the carb cleaned. I would keep doing what you have been doing for a while. After a couple hundred miles if it doesn't improve, you might want to consider having the Harley shop give it a good tune up. Check the plugs ...
May 28, 2013 | 2005 Harley Davidson XL 1200 C Sportster...
The spark plug is only firing on the rear cylinder, I have replaced both plugs, both plug wires, and coil. all parts came from HD dealership and all parts are OEM replacement parts and still only fires on...
Swap the spark plug wires and see it the moves from the front cylinder to the rear cylinder. Your Sportster should have what is known as a "dual fire" ignition system. This means that both spark plugs fire every time the piston comes to top dead center whether the cylinder is on the compression stroke or the exhaust stroke. This causes what is known as a "wasted spark", the spark plug fires on the exhaust stroke. I don't have any experience with bikes made after year model 2000. Most of these bikes are equipped with electronic engine controls that I don't care to learn about. I work on bikes made in 1999 or earlier. I feel pretty confident that Harley still uses the "dual fire" ignition but I'm not sure if they have any other sensors on the bike that would cause the problem you have. Try what I suggested and it may give you a clue as to the problem. Other than that, I have no other suggestions. Sorry I couldn't do more.
Good luck
Jun 11, 2011 | 2006 Harley Davidson XL 1200 C Sportster...
2004 1200 xl sportster after engine has been running for awhile, it will miss alot give it the gas and nothing happens then all at once will run right for alittle while and than start missing again
Sounds like an ignition problem. I don't have a lot experience with the newer bikes as I specialize in the older ones, but it seems to me that Harley went to two coils on the Sportster, one for each cylinder or a "two in one" type coil. I'd check the coil and the spark plug wires. If you can tell which cylinder is cutting out on you, test that coil and the spark plug wire. The primary resistance should be 3-4 ohms across the small terminals of the coil.
Also, if the spark plugs you are running have the screw on ends on them, make sure they are tight.
Good Luck
Jul 21, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
1999 sportster lost power
it might be excessive piston slap,=pistons too loose in bore so loosing compresion.ignition timing too advanced so pinking.carberation too weak,
Jun 29, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
HD 1200 Sportster 1997 model misfiring on rear cylinder
hi paul here,
the coil on my bike turned out to be the problem after checking wires, connections and plugs. brought a used single fire. tried it out after being told that coils usaully go all bad not just half. have not had the problem since and i was conteplating buying ignition and coil combo for hundreds. good luck
Mar 22, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
2006 HD Sportster 1200XL rear cylinder not working
Sounds like an ignition problem. Probably a fowled or damaged spark plug or lose or damaged spark plug lead. Try new spark plugs, I only recommend NGK and you may need to fit hotter plugs for cold weather riding. Plugs are cheap and thats the best place to start.
Dec 16, 2008 | 2006 Harley Davidson XL 1200 R Sporster...
Lands Phones Logo
99 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
