Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave Oven
Serial # J VM240WL 002, Manufacture Date, Dec 1994 Serial # ZL9009 12S
I need instruction for installation this model  in cabinet cavity above the stove. This model was replaced by a newer model in an apartment complex.
  • GE Master
  • 9,042 Answers
You can download GE owner's manuals and installation instructions here.
Posted on Aug 18, 2008
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker Model JVM130G 002 (Date 1989) and the handle is broke. Does anyone know the part number of the handle replacement?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Apr 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker microwave, Model #JVM140H 002, manufactured March, 1990. Sometimes when it is cooking, it switches to a "timer" mode. Other times, I cannot get it to cook - it just goes to...
The problem is in the keypad controller, the microprocessor is mounted on a circuit board along with other parts behind the keypad. Now if this can be repaired it will come down to the availability of a replacement keypad module, you would need to check with the manufacture to see if they carry any stock and price. There might be a possibility that a appliance repairman or tv technician may be able to repair the module if replacement is not available.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Micro/Oven Need to change (inside) light bulb on model #JVM1490SH02 Serial # TH901044K. Where is the bulb located?
While replacing the cooktop light can be done by accessing the cover on the bottom of the oven, replacing the cavity light will require you to pull the oven from the wall and remove the outer cover.
The installation instructions are very handy in this case, and it's best to have two people since the microwave can be heavy and awkward.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions and owners manual
Apr 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need an installation guide for a General Electric Model JVM130K
I have the same model and the instructions at this site on how to remove it will help you. The owner's manual is useless. Good luck!
Dec 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
1994 J EM27L WH 002
I would contact GE Customer Service here.
If you give them your model number, they should be able to give you the model number and nearest dealer for a comparable replacement.
Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
No instruction manuel for model J VM152H 002 (was installed when we moved_
The Owners Manual for the GE JVM152H can be found, saved, and printed from this page: Owners Manual
Hope this helps!
Aug 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
532 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
