Question about Vacuums
Nutone central vacuum shuts off after a few minutes running then will restart after motor cools down I cheked motor and vent ports blown out all clean
  • 706 Answers
Sounds like you have an overtemp switch that is tripping and shutting your motor off. Many motors use what they call a 'snap switch" ( looks like a small disk with two wires on it ) to sense motor temp and if that trips, then it will temporarily disable power to the motor until it cools down enough to allow power to be reapplied. If you are sure everything is clean and your motor can rotate freely ( if there is a restriction that limits motor rotation, more current is drawn to drive the motor thru that restriction ..which in turn will cause excessive heat build up and the temp switch to trip) ... Hope that helps!
Posted on Aug 14, 2008
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
Vacuum shots down after a short time, restarts but runs only a short time
yes that unit has 2 sensors 1 on the motor and 1 on the relay board 1 of them is bad which is making the vacuum shut its like a heat sensors its malfuctioning it shuts the unit down
Feb 17, 2011 | Broan-NuTone VX550 Bagged Central System...
Nutone Model CV353; runs for several minutes and then shuts off. After a couple of hours I can turn on again, but again only last a couple of minutes. Possible relay problem?
Check the filter. If it's dirty, thoroughly rinse it in cool water, then let it thoroughly dry before using. If you don't have an extra filter to use during this time, you should get one.
It could also be a clogged hose or pipe. These would cause the motor to overheat, thus shutting off. Check hose at end for suction. If weak or nonexistent, detach hose and try dropping a penny or dime, or marble, down the hose. If it comes out the end, the hose is probably clear. If this is the case, you need to check other outlets.
Dec 12, 2010 | Broan-NuTone CV353 Central Vacuum
Nutone central vac shuts down after a few minutes of use
this is a very common problem.
If the unit is less than 5 years old and you have your bill of sale it will be covered by warranty. Although one of my customers said that there is a recall on the motor in this unit. That is totally unverified. However, if it is still under warranty, contacting broan/nutone will give you the closest warranty depot, or they may just deal with you directly.
I do recommend that both the motor and the PC board inside be changed.
Good luck,
Mark
Nov 07, 2010 | Broan-NuTone VX475 Bagged Central System...
I have the Nutone 353 central vacuum. The last few times we have used it motor has shut down and then will come back up after an hour or so. Re-set switch does not seem to matter
I would try emptying it out and also cleaning any filters you have access to at the same time. It is usually a sensor for heat that stops the machine and if it is getting full or has plugged filters it will get hot fast cool down and then it will do it all again . Hope this helps you. Good luck
Oct 07, 2010 | Broan-NuTone CV350 Performance Bagged...
Vx550 issues
Heven't fixed it yet, but I've pulled the motor to see what the specific issue is. As soon as I have the problem isolated and a solution, if possible, I'll post it here. I will have to contact Nutone Monday and see what they will do. If nothing, I'll sort it myself.
Tiny
Oct 02, 2009 | Broan-NuTone VX475 Bagged Central System...
VX3000c Keeps shutting down after a few minutes of use
it has a thermal fuse in the motor compartment. it is indicating a over heated motor. check the exhaust for clogs or feel the motor it should be warm but not hot to the touch
if its just warm, the thermal is lying to you and needs to be replaced
Nov 26, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone vx550c central vacuum
You ended chat so fast i guess that fixed ya ??
Aug 09, 2008 | Broan-NuTone VX475 Bagged Central System...
Power Unit VX475 Stops
Checked and found that motor is definitely overheating for unknown reason. Since power unit is still under warranty, solution was to contact local service company for NuTone power unit and have them come out and fix/replace it free of charge.
Jun 27, 2008 | Broan-NuTone VX475 Bagged Central System...
Vacuums Logo
138 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
