Question about Kitchen Ranges
Gas 5 Burner Maytag Gemini Model MGR6875ADW
The issue started with the back left rear burner ignitor did not stop clicking when knob was turned past the ignition point after the burner was lite. Turned that burner off and tried to light the center burner and when knob position was in the ignition point a flash came out from under the knob and tripped the circut breaker. Reset the cb and tried to light the center burner and do not here any clicking and the burner will not light via the knob. The original back left burner that appeared to have a problem with the ignitor now will not ingite with the knob and no clicking sound is heard when knob is used. They will operate with a match. The other three ignite normally. Any thoughts anyone.
  • pinkster7 Sep 10, 2008
    I have had a Gemini range for two days. When I turn one burner on all the others continue sparking and clicking until I turn the one burner off.
SOURCE: Kenmore Gas Range - 2 knobs don't activate ignitor
there is a switch that is broken behind the knobs they cost no more than $15.00. remove the knob so that you can see it it's white in color.
Posted on Dec 10, 2008
SOURCE: Problem with getting burner to light.
All my ignitors spark when I turn one of them on. I'v been told it is normal. I had a problem before and the tech that replace the ignitor said the issues is with alignment. Try to rotate the burner a bit left or right and see if it fixes it.
Posted on Dec 22, 2008
SOURCE: GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Posted on Dec 30, 2008
SOURCE: Ignitors won't stop clicking
there is dirt between the ignitor and the burner or the ignitor is to close to the burner
Posted on Feb 15, 2009
  • 221 Answers
SOURCE: ignitors on all burners are not working
Hi, when any of the knobs is turned to the light position, all burners will spark. That being said, if one or more of the knobs is not switching the spark module, the problem is the switch mounted on the shaft of that burner valve. You need to replace the defective switch or you could turn on one of the good burners (to make the clicking occur) and then light the burner you really want.
Posted on Jan 24, 2010
My Maytag Gemini Gas Range works fine as far as the four burners, the bake on the top and bottom oven, but the broiler on the top oven does not work. Is this a pilot issue? I really appreciate the help,...
If the broiler burner is not coming on it may be a bad ignitor or the ignitor may not be getting power. Observe the ignitor when you turn in on ans see if it glows at all. If not then test for power to the ignitor if you have power and not glowing or lighting replace the ignitor. If it glows but does not light the ignitor may just be weak replace it.
Nov 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I GOT THE BURNER IGNITOR WET WHILE CLEANING STOVE...IT KEEPS CLICKING...WHAT DO I DO
It will stop once it drys out. The best bet is to unplug the electrical power cord and let it dry overnight. Plug it back in the morning and it should be fine. The moisture is most likely in one of the switches just behind the knobs.
Apr 21, 2010 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag gemini gas range--3 burners wont light, they don't get the signal to light when you turn the burner on. They do light if you turn on one of the burners that work and one that doesn't at the same...
Hi, there is a switch on each burner control knob shaft. These switches wear out and are easy to replace once you remove the panel over the knob area. Each switch has 2 wires plugged into it and costs around 5 to 10 dollars. Any switch causes all burner electrodes to spark. Good luck,
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Has anyone else had a serious problem with the electrical wiring in their Maytag Gemini Gas Range? Without using the stove, the ignitors started firing and then stopped when I turned all the burners on....
Same problem here - and I have read about others with this problem. Usually blamed on moisture getting into the control unit ( which is under the backmost burner knob). I did not have a spill on the cooktop, nor was I "over zealous" cleaning. Looks like a bad design. Waiting to hear from the technician how much THIS is going to cost me...
Jan 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Kitchen Gas range
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Dec 21, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
300 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
