Question about Dell Dimension 8200 PC Desktop
Dell Dimension 8200 Internal Hard Drive Enclosures
It may become necessary to drop my internal Dell Dimension 8200 slave drive into an external enclosure and I need to know what size the drive is to buy the correct enclosure. Can anyone please tell if they are 5.25" or 3.5" IDE drives (I'm thinking 5.25" but wanted to be sure).
Also if you know of a good inexpensive online store or brand to recommend that would be a bonus!
  • Freespoken Aug 14, 2008
    Nevermind... as it turns out I got my system working as fortunately all that was wrong was a loose graphic card from the plastic hook breaking on the retaining bracket. Now all I need to find out is where to get a few retaining screws to hold the PCI cards down or some work around for the broken bracket.
    If anyone has advise on this I could use it.
    Thanks anyway.
  • Freespoken Sep 01, 2008
    Seriously doubt any Dell Dimension 8200 is still in warranty, for instance mine is 7 years old. The bracket is an integrated part of the case and unless the entire case is replaced (never happen), the bracket must remain broken. It's not that bad fortunately, even with minor ingenuity a person 'could' manage to create a makeshift latch using wire in lieu of retaining screws. My father passed on such obscure skills to his only daughter over the years and I'd considered this. Only hurdle is living on a small island with very few rudimentary resources which makes it take much longer to obtain necessary materials. Ordinarily I don't ask anyone's help unless in a pinch as we must be more self sufficient here.
    I did however find a friend with several retaining screws needed to secure PCI cards. The rest I'll discover... such as replacement drive size from Dell. Thanks for your input Mohammed, you are the only one who responded and I appreciate it. ;^)
  • 70 Answers
Dear Sir:
You will not get this bracket in any store however you can contact the dell support and if your system is in warranty they will send you free of cost.
Let me know if you need any further assistance and if you have a moment to accept and rate the solution I would greatly appreciate it.
Posted on Aug 31, 2008
I'm trying to increase hard disk space on a Dell
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Jan 01, 2013 | Computers & Internet
Can i move my 2.5 inch hard drive from my dell inspiron 6000 laptop to my dell dimension 8200 desktop pc?
Hi yes you should be able to get a usb hard drive caddy off ebay for about £10-15 and you can then veiw it as an external hard drive and transfer photos, documents ,etc from it.
Hope this helps, if it does please rate me
Jul 14, 2010 | Dell Dimension 8200 PC Desktop
HOw to copy an external hard drive to an internal hard drive.
Open the folder you want to dump the files into, open up the external hard drive (plug into usb, and access from "my computer") ctrl + A to select all, and drag and drop
Oct 15, 2009 | Dell Dimension 2400 PC Desktop
Cannot boot up Inspiron 8200
Could be a tough one. Can you get into the bios ( F8  or F10 ) while booting and check if the HDD is being recognised in the first place ? If it recognises, then check for Boot sequence. I would also suggest to try the Recovery CD that came along with computer.
Feb 02, 2009 | Dell Inspiron 8200 Notebook
Trying to add another internal hard drive to Dell Dimension 3000
Ok... one end of the ide cable goes to the board... make sure that's plugged in correctly and has a blue connector.... second... the last drive on the other end has to be the master... the drive before that is the slave... if that setup is not working ensure that the drivers are set for master and slave... also make the power is pluigged into both drives
Jan 24, 2009 | Dell Dimension 3000® Pentium® 4...
Trying to install hard drive on Dell Dimension 8200.
Sounds like the drive from the 4700 is a SATA drive which uses a different connector than the 40-pin IDE. I couldn't confirm it, but the 8200 may not have SATA connectors for this type of drive. Although the 4700 appears to have both SATA and IDE.
Dec 07, 2008 | Dell Dimension 8200 PC Desktop
Motherboard blew up
I would recommend buying a replacement computer, and install the Dell IDE drive in an external 3.5" IDE hard drive enclosure. This way you can pull your information off the the Dell hard drive, and then blow it away.
Keep in mind that new computers use a SATA drive, your old Dell '8200 has an IDE drive. Also keep in mind that your Dimension 8200 drivers won't work on the new computer.
You might be able to install your Dell drive as a slave if you have an open IDE channel available.
Good news is, your old Dell uses RAMBUS memory, which is worth a lot. It's a good parts computer, and most people who look for computer parts know of the bad capacitor issue on Intel made Dell motherboards from that era.
May 15, 2008 | Dell Dimension 8200 PC Desktop
Replacement Video Card - Dell 8200 w/ NV25
I have a couple of graphics cards that will do the trick. Email me back and I will help you out.
May 14, 2008 | Computers & Internet
External hard drive not recognized
I recenctly bought a my book 500 gig drive and it is usb.
the firsttime I plugged the usb cable in it worksed. I had only a 40 gig ide harddrive and so I ordered an internal 500 wd hard drive to replace it. The internal 500 gig is a sata drive. first I cloned the 40 to the sata 500 and then copied the external 500 to the internal. I mover the cables to then make the internal 500 sata my boot drive. The computer would no longer show the external e\when i used the windows explorer. the device manager said it was there and working with no problem but windows did not see it.
After several experiments with diferent configurations I have concluded my motherboard wasauto configuring the external and internal 500 drives as drive 0. Since the usb was detected first and was notthe boot drive then windows assigned the internal drive as drive 0 and since the usb drive was drive 0 also it would not work. windows ignored it. my solution was to return the ide as the boot drive and plug the sata into a slave port. with that configuration both drive are seen and work normally. It took me several days to find this arrangement. so since my sata ports are auto configure and the external has a sata connection i will install an esata port adapter and try to hook it up as a slave sata drive so i cab\n use my internal 500 sata drive as my boot drive.
sorry this was so long but it is my solution to what others may be facing.
May 12, 2008 | Western Digital My Book Essential Edition...
Dell Dimension 8200 PC Desktop Logo
236 people viewed this question
Alun Cox
