Question about Smeg A2.2 Gas Kitchen Range
Smeg Oven SA 20 XMF
I can no longer read the temperature setting through the wee glass window. A replacement panel is out of my finances. I want to put a cardboard ring around the switch and show the temperature settings by writing on it, or some other solution. How can I find out the settings?
  • 66 Answers
SOURCE: Replacing front panel
please write the M# so ican help you
Posted on Dec 29, 2007
  • 409 Answers
SOURCE: Smeg A2 - Oven gets too hot
is there a heat probe inside the oven? sound like you owen is overheating. i would check the TOD, if the oven has one. this thermostat regulates the temperature and if it's "open" it needs to be replaced.
Posted on Sep 13, 2008
  • 409 Answers
SOURCE: SMEG A 2.5 Range Oven
sound like the TOD to me. have a technician replace it.
SOURCE: My Smeg oven heats up
Hello, my problem will soon be resolved by employing a professional smeg electrician who said I needed a new thermostat. Thank you for reading but I no longer need 'fixya' assistance this time around.
Posted on Dec 22, 2008
barterjoe
  • 344 Answers
SOURCE: can anyone supply a wiring
Looking at http://www.smeg-service.co.uk/support/index.php I have come to the conclusion that the best wat to have this problem resolved is to post it to the help forum or hire an engineer. Smeg has locked down any drawings. Take some pics and draw the wires and you might get someone to figure it out for you. Always remember that the company certified technicians can fix it the right way the first time ;)
Good luck.
Posted on Feb 26, 2011
Hi - I have tried to clean the internal glass panel of our Smeg cooker using an oven cleaner.
The brown stains are on the inner surfaces of the "sealed" glass panel.
Jan 08, 2018 | Smeg Ovens
I need to know the temperatures in celcious for gas marks 1 to 6 in smev motorhome gas oven please
you will have to talk to a smeg technician
normally the numbers do not refer to a degree reading but rather a flame setting
Jul 05, 2017 | Kitchen Ranges
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Fan bake on smeg oven not heating ,mod SA 9066XS
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 02, 2012 | Smeg Ovens
SMEG F170-6 Inner Door Glass
no this glass is heat toughend throug out
Feb 17, 2010 | Kitchen Ranges
I have a smeg self cleaning oven on the first occasion I used it when it was just out of warranty to glass shattered and I had to pay eighty euros for a replacement. Last Tuesday I used the self cleaning...
do not use abrasive cleansers on the glass,fine scratches will cause failure in high temperatures. do not use Philip again untill you call around for the best price.!
Sep 23, 2009 | Smeg DO81CSS Electric Double Oven
My Smeg oven heats up to extremely high temperature even when the gauge is on 50 degrees celcius so I've stopped using it because everything is getting burnt. To identify the model just before the word...
Dec 22, 2008 | Smeg Kitchen Ranges
Sep 13, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Glass breaking
go to a supermarket a buy a thermometer that is oven safe.put the thermometer in the oven and set it to 350 degrees.when the oven light goes out open the door and see what the temp reads on the themometer.it could me the tstat,are you getting the correct voltage to the element or not sure?
Aug 13, 2007 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Smeg A2.2 Gas Kitchen Range Logo
52 people viewed this question
Top Smeg Kitchen Ranges Experts
ashburton
Joseph Mueller
Joseph Mueller
Your Consultant
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
