Question about Ruud UBHC Air Conditioner
Rudd AC Leakage
My unit cools fine but it is leaking all over my garage floor. I changed the filter but it is still leaking puddles. What should I do?
  • 1 more comment
  • Anonymous Sep 02, 2008
    unstop the drain line
    How do I unstop the drain line
  • edgarc84 Sep 05, 2008
    I am having this same problem. My drain line seems clean and the water seems to be coming from the sides.
We have flushed the drain time and time again. It is still leaking. It's very frustrating.
Posted on Sep 21, 2008
Unstop the drain line
Posted on Aug 14, 2008
Puddle of pink fluid on the garage floor
Maybe it is transmission oil . If it is coolant change the coolant bypass hose and upper main hose for a start .
Jan 23, 2013 | Chrysler Pacifica Cars & Trucks
Kohler 20hp Craftsman mower started leaking fuel out of air filter and exhaust
i have been finding that the needle valve in the carb has not been seating from the newer fuel replace both the needle valve and the seat change the oil and you should be good to go i add a shut off valve to the ones i service and advise that the fuel be shut off when not in use and run the carb out of gas when not using for ever day
Jun 18, 2012 | Garden
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
A/c heater & massive drain/leakage on DRIVER floor only. I have had fresh fluid put in twice but every drop drains into the floor. The ac fluid usually will not drain if I do not run the unit, but...
The condensation line can be cleared from under the passenger side of the car just behind the front tire, it can be done with a vacuum cleaner, But this doesn't sound like an ac issue, it sounds like the heater core is leaking.If you check your radiator fluid and it's getting low or that is the fluid in which you are talking about then this is the heater core and not ac related. The ac doesn't use liquid that is changable but rather a gas called refrigerant.
Aug 17, 2010 | 1995 Pontiac Grand Am
Water puddles leaking our of overflow pipe onto floor
sounds like your pressure relief is leaking. Make sure your home water pressure isn't abnormally high (above 80 psi). As long as your water pressure is fine, you should replace the pressure relief.
May 25, 2010 | Noritz 6.3 Gallon Residential Tankless...
Why would a dryer be leaking water at the bottom?
look for a restricted vent . and a cold floor or room . this would cause condensation and would leak from inside / causing leakage on floor in or around the dryer .. hope this helps . pls leave feed back .. mm
Dec 12, 2009 | LG DLE3777 Electric Dryer
My 2002 Saturn L300 has been losing coolant over the past six weeks. I had to fill the resevoir twice during that time period. The coolant level was 1/2" below the cold line and there was no coolant on the...
This may be the first sign that your water pump is failing. First sign is a leak. Crawl on your back under car if you can see if you can see it coming from front of engine near a pully that would turn your water pump. There is a "weep hole" it may be driping from.
Sep 05, 2009 | Saturn L300 Cars & Trucks
Puddle of oil on garage floor under passenger side of engine
Please drive to a garage and let an expert examine if there is an oil leakage from your oil swunp or the oil filter is not well fitted.
It could be that the gear box has shifted too.
good luck. Do this fast on time.
Rate this please
Apr 11, 2009 | 2005 Toyota Avalon
Air Conditioning Unit is leaking badly, has mold and ice.
soundls like the condensate drain is clogged and coil is dirty. look for a plastic pipe inlet where water would flow to.. you may be able to clear it by blowing it out with compressed air. you can also pour bleach into it to address the mold problem. if the coil is icing up it is because it is dirty. to verify this, let the unit run in ac mode for about an hour and check to see if you have air flow from the vents. if you do not, then the cooling coil is covered in ice, thus blocking air flow. you should have a qualified ac person clean the coil and check the refrigerant charge on the unit. one thing to consider, change your ac filter often, at least once a month in hot weather.
Sep 14, 2008 | Intertherm Heating & Cooling
Ruud UBHC Air Conditioner Logo
211 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
