Question about Dometic Rooftop RV Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
Unit was running fine. 1 year old unit. Air conditioner will turn on and compressor runs for about 1 minute. Fan never turns on in camper. What could be the cause? Thanks.
The fan will not come on when I turn on that switch only.
Posted on Aug 14, 2008
  • Dometic Master
  • 6,674 Answers
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
  • Mike Butler
    Mike Butler Aug 16, 2008
    Shut power off to AC unit. Try going up on the roof and look through the cover and see if you can see the fan blades. Slide a stick or something through the cover to give the fan blade(s) a little spin by hand. Couple of rotations is good. Now go back inside, turn on AC and see what happens. I've had about 10 this year at start of season, that just hit a dead spot in fan from sitting, and this cured them all, luckily for the customer. Let me know how you make out.
Window unit (110) cools for a few minutes then stops cooling just fan air unit is about 6 0r 7 years old
It sounds like your compresssor is shutting off on an overload. After the overload cools down the compressor comes back on until the overload heats up and shuts the compressor off again.The fan keeps running as it is not on the same circuit as your compressor.
Aug 02, 2011 | Carrier YC273D Air Conditioner Window/Wall
Fan motor will not run.
Make sure the fan turns freely by hand. It is possible it is overheating and turning off.
May 02, 2010 | Goodman CLJ36AR42 Air Conditioner
RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
May 28, 2009 | Goodman CKL60AR60 Air Conditioner
Bad bearings on the motor or check the fan rotations . Air should always blow out the top and **** in through the sides or coils.!... Thank-you-very-much!
Aug 25, 2008 | Goodman CKL60AR60 Air Conditioner
HBD 160-H Hampton Bay Air Conditioner
The fan alone on an A/C unit draws alot less amps than a fan and compressor. I would guess that your fan and compressor draw around 15 amps when bnoth are on. The unit should be on its own breaker or fuse (whichever you have. As things get old, like fans and compressors, they wear out and will draw more amps.
I see you have 2 choices,:
1) place the A/C on its own circuit with nothing else on it. This may buy you some time until you can replace the unit.
2) Buy a new A/C as the newer units are more energy efficient, and last longer.
Jul 07, 2008 | Hampton Bay HBLG5004 Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
658 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
