HP Color LaserJet 1600 Printer turns paper grey
I bought this printer new and shortly after I purchased it, every page that I print turns a light grey. When I use cardstock, the printer makes the paper like like a sheet of marble. I have changed tones, but with the same results. I have contacted HP, but they said that they have never had this problem reported and told me to take it to an HP repair shop. I take it in a HP authorized printer repair shop, but they could not find any answers to the problem.
  • 8 more comments
  • Anonymous Oct 28, 2008
    exactly the same dilemma
  • donwitt Oct 30, 2008
    Same exact problem
  • Anonymous Nov 06, 2008
    same problem, but only when printing in color
  • Anonymous Nov 24, 2008
    Same exact problem, HP 1600.
  • bvillont Dec 08, 2008
    I have the same problem with an HP LaserJet 1320. Help!
  • jace1127 Dec 16, 2008
    I have the EXACT SAME problem with the same printer. I tried printing just white to "Clean" the rollers but it doesn't work. All my colored sheets look gray!!!!
  • Anonymous Jan 06, 2009
    Same problem, -I've had the printer for a few cartridges worth of ink, maybe a year or so. The grey is not too noticeable now, wondering if it will get worse over time?
  • krackerjack Jan 10, 2009
    It doesn't make any difference if I use INKJET paper or LASER paper. It still leaves a gray cast to the paper.
  • Anonymous Apr 14, 2009
    HP color laserjet 2600 does the exact same thing, any paper other than copy paper turns gray, no good paper will go un-grayed.
  • pozcanon Apr 19, 2009
    I have the same problem, I called HP and argued with them. All they did was bounce me from call center to call center and still no solution!!!
    What a bad investment... I'm never buying a printer from these bozo's again!
It seems to help it I leave printer on all the time. It randomly starts recalibrating. I imagine the more you leave it on the more it does this. I had the grey prob for a while, but it went away with the next toner. This might be solution, but I'm not sure.
Posted on Feb 28, 2009
  • 40 Answers
I had this problem when I used INKJET paper instead of laser paper.
Posted on Jan 10, 2009
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Aug 21, 2014 | HP Color LaserJet 1600
Am confused,i want to buy a colour laserjet printer and left with only two options which one should i buy btn hp1600 and cp1525
hiii
Its depends on your printing needs.Printing quality almost same these two printers. If u buy hp 1600 u will get more pages than cp 1525.But u should think about the toner cost. Check your local market price for each toners.Here i will give u the toner model numbers for ur required printers.
hp 1600 - q6000- black,q6001,q6002,q6003 each three colours.- Page yield 2500 pages for black ,2000 pages each colours.
hp cp1525- ce-320a(128a),ce321,ce322,ce323- Page yield -2000 pages for black,1300 each colour pages.
So I am sure hp 1600 toner very costly than 1525 toner.If u dont have huge volume printing better i suggest u buy cp 1525 model.Also this model offering wirless printing .
U can refill this toners lowest cost and getting good results.
sooooooo cheeeeeeers up........select your new printer. best wishes..........
Jun 14, 2011 | HP Color LaserJet 2600n Printer
HP LaserJet 1600 Printer Logo Problem with the HP LaserJet 1600 Printer My hp color laserjet 1600 ''incorrect yellow'' @yahoo.com
LOCAL PC PRINTING GET QUICK BUT DOMAIN USER NOT GET PRINT MANUALY PRINTER SPOOLER RESTART IT WORKING HOW TO SOLVE
May 14, 2011 | HP LaserJet 1600 Printer
Why the color fade towards the edge?
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper pieces is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer for settings to ensure everything is order.
lastly, check hp's printer trouble shooting web site for more information. or the printer head might had a fleck of dirt on it, run a print test
good luck.
Apr 29, 2010 | HP LaserJet 1600 Printer
Yellow cartridge says low after printing 200 pages for hp laserjet 1600
200 is not much, but possible if you print a lot of pictures at paper size. Normally when a HP 1600 starts notifying about low toner, you still have about 20 %.
Apr 09, 2009 | HP Color LaserJet 2600n Printer
Smudge mark along entire right side of every page.
HP 1600 is quite a decent little printer, so you shouldn't be dissapointed - if it's working properly, which clearly it's not in this case.
It seems that you have 2 problems here.
Firstly it shouldn't click loudly, so you need to be talking to whoever you bought the printer from.
The smudging - is probably a dirty fuser.
There are laser printer cleaning sheets, that will work quite well, but ideally it needs a little bit of dismantling to get at the fuser to clean the two fuser rollers.
I've seen lots of these with dirty fusers, and a clean with IPA does the trick.
Jan 03, 2009 | HP LaserJet 1600 Printer
Printing quality off? 2550 HP laser jet?
When installing new cartridges, it's always a great idea to perform a cleaning and recalibration of the machine. Below are the steps needed to do just such a task. You may want to print these out or save them somewhere for future reference as well. They are directly from the HP website.
Please rate the tip accordingly and thanks for using Fixya.com.
Cleaning the printer
  1. Verify the printer is turned on and in the Ready state.
  2. Open the HP Color LaserJet 2500 Toolbox. Click Cleaning Page on the Troubleshooting tab, and the click Print (HP Color LaserJet 1500 or 2500) or Cleaning Page (HP Color LaserJet 2550). A page with a pattern prints from the printer.
  3. Remove any paper that may be in tray 1.
  4. Remove the page that printed and load it face down into tray 1.
  5. At the computer, press Clean .
Calibrating the printer There are two methods of calibrating the printer manual: at the printer or from the Toolbox on the computer. From the printer Turn the printer off and then on again. From the HP Color LaserJet 1500 or 2500 Toolbox on the computer
  1. Open the HP Color LaserJet 1500 or 2500 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 1500 or 2500 Toolbox icon on the computer desktop.
    • Select Start , Programs , HP Color LaserJet 2500 , and then HP Color LaserJet 1500 or 2500 Toolbox to open the Toolbox from the Windows desktop.
  2. Click Diagnostic Tools on the left side of the screen on the Troubleshooting tab.
  3. Click Color Calibration to perform the calibration procedure.
From the HP Color LaserJet 2550 Toolbox on the computer
  1. Open the HP Color LaserJet 2550 Toolbox in one of the following ways:
    • Double-click the HP Color LaserJet 2550 Toolbox icon on the computer desktop.
    • Select Start , Programs , Hewlett-Packard HP Color LaserJet 2550 series , and then HP LaserJet Toolbox to open the Toolbox from the Windows desktop.
  2. Click Print Quality Tools on the left side of the screen on the Troubleshooting tab.
  3. Click the Calibrate Now button to perform the calibration procedure.
Nov 04, 2008 | HP LaserJet 2550Ln Printer
My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Jun 04, 2008 | HP LaserJet 1600 Printer
Printing on card
160gm is too thick for the printer. Printing a couple of sheets should be okay, but more than that and you will damage the cartridges hence the "grey" haze. Check your printer specs -- max. gm on these printers is probably 105gsm.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
693 people viewed this question
jasbo
jasbo
