Question about Microsoft Windows XP Professional
Network problem i am facing problem with 2 computers in my domain, that it is showing the network connected,but not taking any ip address from dhcp.packet sent 0 receiving also 0.also pc is running very slow
  • ntn_bobade Aug 14, 2008
    have same problem
  • blu3yy May 11, 2010
    Have you checked if you've got a firewall on the PC? Have you tried to release the DHCP and renew a lease?
    What happens if you goto a command prompt and type "ping localhost"
  • 86 Answers
Ya - firewall or not sharing properly. Rather specify an IP adress range for each workstation.
Also, check router of sharing cable
Posted on Aug 16, 2008
How to fix Ip address conflict problem?
This is due to same IP address has detected in the same network. Change your local PCs IP address by clicking Settings > Network Connections> Local Area Connections. Right click on Local area connections and Properties > Select Internet Protocol [TCP/IP] > properties > Use following IP address enter new IP address (eg; 192.168.0.250). Let me know for further assistance
Feb 17, 2012 | Computers & Internet
JN763. Access rejected from your IP address.
To resolve this problem, follow these steps.
  1. Using the Internet Service Manager (Microsoft Management Console), open the Internet Information Server (IIS) snap-in and select the Web site reporting the 403.6 error. Right-click the Web site, virtual directory, or file where the error is occurring. Click Properties to display the property sheet for that item.
  2. Select the appropriate Directory Security or File Security property page. Under IP Address and Domain Name Restrictions, click Edit.
  3. In the IP Address and Domain Name Restrictions dialog box, if the Denied Access option is selected, then add the IP address, network ID, or domain of the computer that requires access to the exceptions list.
    In the IP Address and Domain Name Restrictions dialog box, if the Granted Access option is selected, then remove the IP address, network ID, or domain of the computer that requires access to the exceptions list.
Jan 31, 2011 | Microsoft Computers & Internet
May 2008 domain controller is up and running but i cannot join it with my windows 7 laptop, "domain path not found"
Ah this is an easy one, make sure the laptops MAC address (this can be found by going into the laptops command line and typing 'ipconfig /all') Then you need to go into Doman users and computers (active directory) and add that MAC address to the computers group.
If this doesn't work...make sure your laptop is connecting through the same network. use the cmd line tool Ipconfig /all to find out the ip address of your server and your laptop. If your laptop's default gateway doesn't match that of your server's...you could be cross networking. Try the "ping" command like this go to the command line on your laptop and type Ping <ip address for server> if you can ping it, you can connect with it....also check your group policy that enables wireless connections.
Dec 15, 2009 | Dell Dimension 3000 PC Desktop
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Jul 27, 2009 | Computers & Internet
Difference between DNS and WINS
WINS is Windows Internet Naming Service, a system that determines the IP address associated with a particular network computer. This is called name resolution. WINS supports network client and server computers running Windowsand can provide name resolution for other computers with specialarrangements. Determining the IP address for a computer is a complexprocess when DHCPservers assign IP addresses dynamically. For example, it is possiblefor DHCP to assign a different IP address to a client each time themachine logs on to the network.
__________________________________________________
DNS, a.k.a Domain Name System is a database system thattranslates a computer's fully qualified domain name into anIP address.Networked computers use IP addresses to locate and connect to eachother, but IP addresses can be difficult for people to remember. Forexample, on the web, it's much easier to remember the domain namewww.amazon.com than it is to remember its correspondingIP address (207.171.166.48). DNS allows you to connect to anothernetworked computer or remote service by using its user-friendly domainname rather than its numerical IP address. Conversely, Reverse DNS(rDNS) translates an IP address into a domain name.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Presario 700
First, you need 2 make sure if all your LAN devices are installed correctly on your laptop: To do this , right click on "My Computer" then select Manage from the menu that appeared. A window will open. Search and Locate then left-click "Device Manager" in the left colum. The right coloum should now contain many things. These things are all the devices that are installed in your system. To see if one or more of them are not working properly, there would be yellow, black or red exclimation marks (warnings) next or above their icons. If you do not see any exclmarks, then everything is working well.
Next, you'll have to change or edit your a.) IP address, b.) Network ID, c) WORKGROUP.
Inorder for your LT to communicate on a network, your LT must either have a static or an automatic ip address. An static IP means, that you as a user, specify an IP address and an automatic IP address will be "assigned" to you by the "server".
To check if you have an static or an auto IP click on start, then on "My network Places".A new windows should have opened now and 2 your left you should find the "View Network connection" globe icon. If you click on it the Network connections should appear in the right window. Right click on your Lan (Network Adapter) icon and select "Properties". Scroll down in the list 2 the bottom, to reach the "Internet Protocol (TCP/IP)", then click on it once and then click on the "properties" tab to open it. A small window shouls appear, You will see an option that says "Optain IP address automatically" and "use the following Ip address" If you are on a "home network, it would be better 2 use your own... IP: 192.168.0.202 , SN: 255.255.255.0
We shall leave The Gateway box blank for now because that would belong to internet configerations like asdl or idsn.
If you are on a corporate, business Network, then it is most likely an automatic IP address.
Inorder for your LT to communicate on a network, your LT must be member of a "Workgroup" or a "Domain". To check your "member" configerations, right click my computer and select properties, then click on the "computer name" tab. Your OS should indicate: Your Computer desc, your Full computer name and Workgroup. If you are on a home/private little network, each entity in your LAN must have the SAME workgroup but each must have a UNIQUE IP. If you are on a corporate/business network, you will be added to a domain. To change your settings, click on the "Change..." button at the bottom right of the window. A new windows should appear and you can change to the settings you want.
Now, we have to test connectivity and if your IP and LAN are set up. To do this, click on start, click on run, then type in "cmd" without the quotes. A command prompt windows should now appear, so you will type in "Ipconfig". The output should show you your network connections, their MAC addreses and their IP addresses. Next type in the following "ping ::1" or "ping localhost", without the quotes. In this way, we test if OUR network is up. Now we need to check if we can see or info other computers on the network. FInd out another computers IP or Computer name thats on the network. Then type in "ping COMPUTERNAMEORIP" where computername or ip is the computername or the ip of the other computer without the quotes. you will see something like this when successful :
Reply from 176.16.63.80: bytes=32 time<1ms TTL=127
Now you know that your LAN is working.
You will also need to check your firewall settings and if you have file and printer sharing enabled.
Kind Regards
Stef
Apr 17, 2008 | Compaq Presario 700 470024-192 Notebook
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
