Question about Remington Polesaw Wizard
Broken clamp nut
The nut that locks the pole in position is crumbling/ broken. need repair solution
  • 4 more comments
  • denniscobb Sep 17, 2008
    Clamp is broken. Owners manual on line doesn't show thw same clamp. The one I have has a lever that opens loosens and tightens a collar. It is not a twist type as shown.
  • alsvill Sep 21, 2008
    I have the same problem.
    Plastic compression fitting that locks pole is broken.
  • Anonymous Oct 05, 2008
    Me too!!
  • Anonymous Jan 08, 2009
    same here
  • Anonymous Mar 22, 2009
    I have the same problem but mine is the one that just tightens by turning it tighter. I did not see a diagram of the one you are talking about, but they did not have a parts list. I am going to try a metal pipe clamp.
  • Thomas F. Schneider May 11, 2010
  • 188 Answers
SOURCE: Broken clamp on Remington Pole Saw
I just checked with Master Parts and they have part number 121560-01 in stock. You can contact them toll free at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps you!
Posted on Jul 20, 2009
  • 188 Answers
SOURCE: pole saw lock broken when i extend handle need new lock
I just contacted Master Parts and they have that part available (121560-01). You ca contact them toll free at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
VtToolMan
  • 704 Answers
SOURCE: where can I find a replacement locking nut for the
Without the model number, I can't provide you with the part. However, you can go to masterparts.net and click on the Remington chain saw link and with your model number, get a line drawing and list of all available repair parts and pricing.
They have almost all the parts for even most discontinued Remington chain and pole saws and have a toll free number you can call, once you have your model number to provide them with. 1-866-672-6040
Hope this helps and best regards!
Posted on Jul 31, 2009
dontbother10
  • 2220 Answers
SOURCE: the clamp that secures the pole when extended is
It was working yesterday GL
http://www.desaparts.com/index.htm
Lou
Posted on Sep 29, 2009
dontbother10
  • 2220 Answers
SOURCE: Pole Saw RPS96 - - Saw 108526-01 - - The outer
Your pole saw is at the bolttom of the page here:
http://www.desaparts.com/remington-chainsaw.html
The parts list that appears is a chainsaw. Please phone them @ 1-800-475-5660, ask for assistance and explain this little glitch. Thanks HTH
Lou
Posted on Oct 03, 2009
I need a Coupling Nut for my electric pole saw
lots of luck there, if you have tried Remington, with no luck may i suggest a automotive hose clamp and a piece of inter tube.
Nov 07, 2013 | Remington Electric Pole Saw
I need coupling collar for my remington pole saw
I experienced the same problem with mine. The collar ring split making the pole saw useless. I am one of those who can basically fix anything you can put into my hands......
I have the solution for you! Loosen the collar ring and ensure the matching edges (where it is split) are clean & dry.....(no oil or residue).
Use JB-Weld (available in most department stores, hardware stores and auto suuplies) to repair the collar ring. Use the standard type epoxy (not the fast drying type). You will also need one other item to keep the ring from splitting again. The collar ring has a 2-inch diameter. Go to a hardware store or an auto supply store and ask for a 2-1/2 inch stainless worm clamp. Be sure to get the wider type that is about one-half inch across the stainless band. The clamp is typically used to connect radiator hoses on automotive engines. Make sure the clamp you get is stainless. Unscrew the clamp using safety in mind.....they typically have a large "straight slot" screw; using a screwdriver is a bit dangerous especially if you have to tighten it very tight. If you have access to a nut driver or a small quality socket set, these tools will enable you to tighten the worm clamp very tight. Do not force the collar ring back into service for a few days to ensure that the epoxy has had plenty of time to cure. I repaired mine a few years ago and it still works great!
Please send me a reply once the surgery and recovery is complete.
The total cost for materials is about $9-$10.
I hope this fixes your collar ring for good!
The plastic female part of my Remington telescoping pole saw coupling nut split and won't hold the extension pole in place. I'm trying to find a replacement or a fix.
Okay here is the Fix for the Remington Pole for the remington saw. Lowes has a plumbing part that will work as I just purchased it 12/2010 The part is by GENOA and its a 3/4" pvc Union and the threads match. Its Lowes part 98996 and its < $6.00
Oct 13, 2010 | Remington Electric Pole Saw
The smallest clamp (bottom clamp) is broken.
Try www.BogenTripodParts.com for that part. There is listed the widest selection of Bogen parts and support more models than any other web site I’ve seen. There are losts of pictures to help find just the right part.
May 05, 2010 | Manfrotto 679B Monopod
The plastic Pole Lock (Thumb Latch)on my Remington electric pole saw is broken. Where can I find a replacement?
RemingtonPower is no longer in production, The "Coupling Nut" was replaced by a "Thumb Latch" neither of these nor the entire pole assembly are available.
You might try this (no promises).
http://store.poolcenter.com/shared/StoreFront/product_detail.asp?RowID=167966&CS=poolcenter&All
Someone recommended using a hose clamp in place of the nut.
I think these are band-aids and eventually you will need a part that cannot be found.
We rarely get inquiries for McCulloch or Poulan electric units. Might be worth a look.
If you care to try on your own start here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Sometimes you can find NLA parts (use part number for above) offered here:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
If you have more questions or need additional help please reply below and I will get back to you. and Good Luck. HTH
Lou
Thank you for using FixYa.
Apr 17, 2010 | Remington Polesaw Wizard
I have a broken nut on the pole how do i fix it?
Remington.com
Master Distributors
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 09, 2010 | Remington Polesaw Wizard
Pole Saw RPS96 - - Saw 108526-01 - - The outer clamp/nut that holds the pole at the selected length has split. I guess I could use a clamp to secure it, but I'd like to replace with the correct part. Can...
Lou
Oct 03, 2009 | Remington Electric Pole Saw
Jul 20, 2009 | Remington Polesaw Wizard
Pole saw lock broken when i extend handle need new lock
I have the model 108526-01 Remington pole saw which has the round pole with a plastic compression nut (which recently broke). Can I buy the newer octagonal pole and if so, does it use the same saw mounting...
I have the sollution, had the same problem with the broken compression nut. Just use two hose clamps, one to hold the pole extended and the other clamps around compression base. Its a cheap easy fix and it work great fo me. The Real Mr.Fixit
Apr 03, 2009 | Remington Electric Pole Saw
Remington Polesaw Wizard Logo
124 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
