Question about Nikon N75 35mm SLR Camera
What setting mean?
On the top knob what do all the setting do? also all the button and slides on camera!
    Guru:
  • Nikon Expert
  • 362 Answers
What you are asking for would require me to write pages and without illustrations it would be difficult. I would suggest you go on E-bay and buy a manual. I just checked and they range from $12 to $20.
Posted on Nov 28, 2008
How do you load it
To open back cover lift knob on top of camera ( this knob has a small arm that unfolds - used in rewinding).
Once open you will see which side is the film side ( under this knob) and the take up side. On the film side raise the knob again in order to insert film case, the top of this should flip over later used to rewind film. with film trail out toward back of camera. Now push the knob down. Film should only be loaded one way so the knob can be lowered into film canister. Lower knob and Film canister is now secure.
Next thread film leader onto take up spool. Some times these have a slot , but most Just have the teeth that fit the film edge.thread the film into slot then unto teeth. You will need to use film advance arm (There should be an arm on the top opposite side of film knob) you would move that would advance film.
as you move this arm ( with cover open ) film holes should engage the teeth on bottom and top. ( if you can't advance after 1 or 2 advance arm swings) press take picture button ( releases springs).
continue until film is captured top and bottom. Use the film spool knob gently wind film back into canniester until snug don't over wind. Close cover, take a picture with lens cap on, repeat that. As you wind ,the film cartridge knob should rotate.
You are not wasting pictures film was designed for this waste.
you should know how many photos were on film 12/24/36 pictures.
you may have a knob to set to that number.
When your ready to remove film ,push silver button on bottom and use winder handle ,rotating until free and easy. Open cover mention earlier.
wow can't believe I remembered all that and hope that helps.
Sep 23, 2016 | Photography
I can't seem to get the knob for film advancing off the camera body
There should be a small slide-switch on the wind knob itself. If you slide it back, the knob will rotate backward slightly and pop off the body.
Jun 15, 2011 | Hasselblad 503CW Medium Format Camera
My film wont move on after i take a picture. So it only says one picture taken on the screen ?
The camera may be set to do a multiple exposure and you must take the camera off this setting back to normal mode to remedy this.
1. Look at the top of the camera from the back - on the far left is the knob with the BKT, FLASH, and ISO buttons. On the bottom of the outside of this knob there is a small ring and also a small black unlabeled button to the top left of the knob.
2. Press and hold the small button
3. Turn the ring until it shows the "S" setting
Then fire the shutter - the camera should operate as normal and advance the film after the shutter firing. If it still does not, then your film advance motor may be bad and need to be replaced or repaired.
Nov 26, 2010 | Nikon F100 35mm SLR Camera
The frame counter in my F100 seems to of stopped working
Then fire the shutter - the camera should operate as normal and advance the film after the shutter firing and also increment the frame counter. If it still does not, then your film advance motor may be bad and need to be replaced or repaired or your sensor in the back that detects the frames may be faulty.
Nov 24, 2010 | Nikon F100 35mm SLR Camera
Trying to get the film removed and new film put in
to rewind the film back into the tin look underneath the camera you will see a button, press this, it will disengage the winding mechanism, looking on top of the camera to the left you see a knob. flip out the handle and start to turn this clockwise until you hear a click and the turning become a little easier. if it is hard to turn, ensure the button undeneath is still pushed in. once the film is wound back, lift this knob this should open the back door and of the camera and release the spent film can.
take your new film and take it out if its platic container. place the old film in the same container for safe keeping til it goes to processing.
place the new film into the camera on the left side with the brown tab of the film laying over the shutter window in the middle.
press in the winder knob to help hold the film container in place.
pull out the end of the film and guide it over the two wheels with teeth ensureing that the teeth fit into the perferation holes in the film.
slide the film across the camera to the roller on the oposite side. slightly wind the camera on help guide the film tab into the slot
once in the slot slowly wind the camera on ensuring that the film is running smoothly over the shutter gate.
now close the back of the camera which should click to lock.
now wind on the film until the winder leaver stops
check the ASA or IOS rating of your film from the box it came in.
and ensure this setting is correct on the setting wheel on the right.
if your camera has automatic film recognition then this is not necessary.
you are now ready to start taking pictures again.
Nov 15, 2009 | Minolta X-700 35mm SLR Camera
I cannot access take pivture or video
Hey at the top of your camera lcd, there is a slide button, in 3 settings, the play the camera and the video, try to slide it, if you want to see what you have taken, move it to play, of you want to captured camera, put it in the middle, if you want to video put it to the last. :)
Oct 04, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Self timer where is it. borrowed this camera for an assignment [ no manual] but I can only deduce from online information that the self timer works in all settings found on the top .. the settings knob
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. Start the self-timer by pressing the shutter release button.
Sep 30, 2009 | Canon PowerShot A620 Digital Camera
EF warning light blinking in top left corner of viewfinder.
willwhitman,
this means that your camera is set for the " exposure factor ". just turn the knob back to 1x under the re-wind knob.
Feb 21, 2009 | Pentax ME Super 35mm SLR Camera
Shutter speed on my nikon d80 is to slow
Try CUSTOM SETTINGS MENU 31. (turn off EXP. delay mode).
Dec 28, 2008 | Nikon D80 Digital Camera with 18-135mm...
Can't change iso setting using iso button
If your camera is on auto, you must turn the knob on the top to manual.
Nov 01, 2007 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Nikon N75 35mm SLR Camera Logo
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
