Motorcycles Logo
Posted on May 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Torque settigs on cylinder and head for a 2002 ktm 65
Anonymous
Level 2:
  • Expert 292 Answers
  • Posted on Oct 29, 2011
Anonymous
Expert
Level 2:
Answers
292
Questions
0
Helped
250582
Points
640
Thank you for contacting FixYa with your inquiry. I have been going
over some of the older help requests that have been archieved and
trying to provide solutions for those that didn't get answered. Hope
this information helps.
KTM Torque settings
  1. Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
  2. Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
  3. Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
  4. Brake Disk, rear Brake disk rear Loctite 243 1 11ft lbs
  5. Clamping screws, upper fork bridge Top triple clamp 20Nm 15ft lbs
  6. Clamping screws, lower fork bridge Bottom triple clamp 15Nm 11ft lbs
  7. Clamping screws, fork stubs Front axle pinch bolts 10Nm 7ft lbs
  8. Collar nut, rear wheel spindle Rear axle nut 80Nm 59ft lbs
  9. Hex nut swingarm bolt Swingarm nut 100Nm 74ft lbs
  10. Hex collar screw handlebar clamp Upper handlebar clamps 20Nm 15ft lbs
  11. Allen head screw handlebar support Lower handlebar clamps Loctite 243 4 30ft lbs
  12. Shock absorber top Shock absorber top bolt 60Nm 44ft lbs
  13. Shock absorber bottom Shock absorber bottom bolt 60Nm 44ft lbs
  14. Sprocket screws Rear sprocket bolts Loctite 243 3 25ft lbs
  15. Ball joint for push rod Rear brake pedal pivot Loctite 243 1 7ft lbs
  16. Engine mounting bolts Engine mounting bolts 45Nm 33ft lbs
  17. Engine brace Engine brace 33Nm 24ft lbs
  18. Screw adjusting ring spring preload Shock preload collar bolt 8Nm 6ft lbs
  19. Spoke nipple Spokes 5Nm 4ft lbs
  20. Other Screws on chassis M6 10Nm 7ft lbs
  21. M8 25Nm 19ft lbs
  22. M10 45Nm 33ft lbs
  23. Other collar nuts on chassis M6 15Nm 11ft lbs
  24. M8 30Nm 22ft lbs
  25. M10 50Nm 37ft lbs
  26. Front Sprocket 44ft lbs
What is the torque on 2004 chevy impala head bolt
list of trq specs ' Chevy Impala SS Forum
https://www.impalassforum.com > threads > list-of-trq-s...
Nov. 1, 2009 - If you need the head bolt specs, etc, look on this page: ... Cylinder head torque in the '95 states 3 passes building up to 65 ftlbs. Don't have the ...
Head bolt torque
Feb. 23, 2002
Torque Specs
Nov. 3, 2019
Head Bolt Helllppppp!
Apr. 3, 2010
Head Torque Specs
Nov. 3, 2019
More results from www.impalassforum.com
Cylinder head bolts torque specs 2002 KTM SX 50 Pro Junior LC
  • For all of dads and moms that love to stay home to take care of their loved ones, or rest of people on the search for an opportunity to pull in some extra income for their family month after month let me share a remarkable opportunity to explore...Read more here.......http://www.fox120.com/
Please can you help with all the torque settings for the cylinder head on Hyundai Accent 1.5 1995"
Nissan Frontier, Xterra 1998-05
Torque Specifications
Fig.
TORQUE SPECIFICATIONS
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1998 2.4 (2389) KA24DE
1A Step 1: 22 ft. lbs.
2B 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
4C The cylinder heads and the lower intake manifold are installed together
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 1999 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 2.4 (2389) KA24DE 3.3 (3277) VG33E
all readings in ft. lbs. Year Engine Displacement Liters (cc) Engine ID/VIN Cylinder Head Bolts Main Bearing Bolts Rod Brearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Lug Nuts Intake Exhaust 2000 3.3 (3277) VG33E
1A The cylinder heads and the lower intake manifold are installed together
3C Step 1: Tighten the cylinder head bolts to 22 ft. lbs.
4D Step 1: Tighten the connecting rod bearing bolts to 10-12 ft. lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1998 KA24DE
1- Step 1: 22 ft. lbs.
2- 10-12 ft. lbs. plus 60-65 degrees or 28-33 ft. lbs.
3- The cylinder heads and the lower intake manifold are installed together
4- 10-12 ft. lbs. +60-65 degrees
5- Step 1: 72 ft. lbs.
6- Step 1: bolts 11-22 19 ft. lbs.
7- Step 1: 20 ft. lbs.
8- Step 1: 31 ft. lbs.
9- 83 inch lbs.
10- Stud bolt: 11 ft. lbs.
11- Step 1: 72 ft. lbs.
12- Bolts: 17-24 (M8) 16 ft. lbs.
13- Step 1: 33 ft. lbs.
14- Intake manifold collector:
15- Intake manifold:
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 1999 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2000 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2001 KA24DE VG33E
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2002 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2003 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2004 KA24DE VG33E VG33ER
9- 83 inch lbs.
all readings in ft. lbs. Year Engine ID Engine Displacement Liters Cylinder Head Bolts Main Bearing Bolts Rod Bearing Bolts Crankshaft Damper Bolts Flywheel Bolts Manifold Spark Plugs Oil Pan Drain Plug Intake Exhaust 2005 QR25DE VQ40DE
9- 83 inch lbs.
Main Bearing Torque Sequence
Fig. Main bearing torque sequence-2.4L engine
Fig. Main bearing torque sequence-2.5L engine
Fig. Main bearing torque sequence-3.3L engine
Fig. Main bearing torque sequence-4.0L engine
Nead head torque sttigs asa well big ends torQue settigs
No one can help you without make, model and year
2answers
Cylinder head torque specs for kia carnival 2002 2.5 v6
cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
Can you tell me the torque spec.on head bolts for a 1985 ltd 3.8 thank you
Six IN LINE - 6L
Fig.: Cylinder head torque sequence - 6 -cylinder engine
Cylinder head torquing should proceed in three steps and in the prescribed order. Tighten them first to 50-55 ft. lbs. (65-71 Nm), then give them a second tightening to 60-65 ft. lbs. (78-84 Nm). The final step is to 70-75 ft. lbs. (91-97 Nm), at which they should remain undisturbed.
Six IN V - 6V
Fig.: Cylinder head bolt torque sequence - 6 -cylinder engine
Tighten the head, according to the illustrated sequence in three progressive steps. Tighten the bolts to 50-55 ft. lbs. (68-74 Nm), then 60-65 ft. lbs. (81-88 Nm) and finally to 75 ft. lbs. (102 Nm).
Hope this helps (remember to rate and commene this answer).
3helpful
2answers
Torque setting cylinder head bolt 4 cylinder KIA sportage
I need the torque settings and pattern for a Kia Sportage 2.2
Need cylinderhead torque specification for03chry.t&c van 3.8
Cylinder Head Torque Step Min. Max. Note(s) 1 45 (ft. lbs.) 45 (ft. lbs.) - 2 65 (ft. lbs.) 65 (ft. lbs.) - 3 65 (ft. lbs.) 65 (ft. lbs.) - 4 *90 (degrees) *90 (degrees) 429 Note *: Value is given in degrees. Turn the fastener this additional amount past the previous step.
Note 429: Torque should be above 90 ft/-LBS or replace bolt.
5helpful
Head bolt torque
Hi bengriffith1
You can download a copy of the engine manual from here
It has all the info you need. Any problems with the download just let me know
regards robotek
Top KTM Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Are you a KTM Expert? Answer questions, earn points and help others
