Question about Sony KP-51HW40 51" Rear Projection Television
Watching rear projection tv. A flash and picture went away(Black screen) can still hear program. Is there an easy fix. tv is 13 years old
  • Anonymous Oct 21, 2008
    how to replace the lamp unit
We have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Posted on Oct 20, 2008
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
Won't display tv and there is a black box during dvd play
It sounds like you have the closed-captioning set to "text" mode. When set this way, if captioning is present the set clears the area where the text goes. You don't see the box on channels or programs where captioning isn't being used. On most TV remotes a single button controls captions, so it's easy to get into text mode without knowing it.
Apr 04, 2009 | Toshiba 46H84 46" Rear Projection...
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Screen went black, no picture
A clue to what is wrong is by looking from the back (taking the back off) and looking to see if the three picture tubes have any yellow glow at the bottom of them where the three identical boards are located on each tube.. If you have no glow there you possibly have a resistor R4703 open. It is a 3.3 ohm resistor and feeds the voltage to the filaments in each tube where the glow is suppose to be. If you do have the glow the problem could be much more complicated. Another to check is to see if the menu comes up on the screen. You could possibly be in the wrong input mode, Check your input mode with the input button on the remote The number R4703 is a location number to identify where the resistor is. This is all I can tell you that would not require much more complicated procedures requiring a tv repairman to look at it. If you have an ohm meter you can check R4703 but it must be checked out of circuit. (or at least one leg loose) Hope this helps
Jan 04, 2008 | RCA P52930BL 52" Rear Projection...
NO PICTURE
The leading cause of this type of failure is convergence.. Replace both convergence Ic's Stk392-110 and check all 2.2 ohm resistors in that circuit... This repair on this particular unit is fairly easy because the convergence amps are mounted in such a way to easily remove the left board for field servicing...
Have a great day!
Bill
Nov 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV ready
Your projector bulb burned out, easy to replace yourself
Oct 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KP-51HW40 51" Rear Projection Television Logo
168 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
