Question about Kitchen Ranges
I need to replace the rubber gasket in my Coleman Peak 1 Backpacking stove. I bought a replacement pump which it is too long for my stove, but is the only thing I could find in Seattle. How do I get the rubber gasket off the new pump and put it on the old without tearing the rubber gasket?
Oven door will not close completely, therefore oven light is always on and the outside manual switch doesn't turn light off or on. The gasket around the window is brittle and coming away from its anchors in a number of places. I would think it needs to be replaced. Where is this part available? either on line or in Toronto, ON. M5R 3M6 Canada
Posted on Aug 14, 2008
Where can I find a manual for a Coleman Peak 1 Model 576 stove
Try Coleman!
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Aug 19, 2014 | Camping, Backpacking & Hiking
Can I buy a replacement grill?
You could try Coleman, they might be able to supply one.
Wichita, KS 67219
1-800-835-3278
TDD:316-832-8707
Jul 03, 2014 | Coleman Vintage Bernzomatic Deluxe Propane...
Coleman 5423b701
Try Coleman directly.
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
What is the recommended stove for summer backpacking?
The recommended stove for summer backpacking is a canister or an integrated stove system.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
I have coleman component 443 camping stove. While pumping, the input air by the pump leaks just after the pump. I guess the cap of pump should be replaced. I tried to buy the part in Vancouver,...
yms3023000-
The only official Coleman repair facility is in Wichita, KS.
Try oiling the flexible gasket at the end of the pump. More often than not, a leaking pump is is due to the gasket drying out and not forming a proper seal.
Hope this helps.
Regards,
DIYpro
Jun 05, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
I cant seem to get pressure in my coleman 421E stove
Try putting a couple drops of oil down the shaft of the pump.(thingy).
There may be a small hole at the top of the pump(where the plunger slides up and down) to add a drop or two of any light oil.The gasket in the pump should swell back up and the pump should work again.
These gaskets dry out every now and again.
Good Luck !!!!
May 23, 2010 | Coleman Grill
Coleman Peak 1 400A fuel/air mix wont ignite
krimkramm, any luck finding a solution? www.spiritburner.com seems to be a great source of information if you are still trying to fix your Coleman 400A. If you would like to sell it, I am looking for one for my local Boy Scout troop. Send me an email at braddotroberson@verizondotnet after replacing the dots with a you-know-what.
Brad
Aug 10, 2009 | Kitchen Ranges
How to operate a coleman two burner stove using liquid fuel
If you are talking about the old type that runs on Coleman fuel, start by putting some oil in the hole beside the pump knob to make sure that the gasket is lubricated. Fill with fuel and pump it up, keeping your thumb over the hole in the end of the pump knob. When you have pumped up enough pressure, turn on and light the main burner, then secondary burner if necessary.
Jul 06, 2009 | Coleman Sport & Outdoor - Others
Coleman Peak 1 Model 400 stove We have had this stove for 20 years at least. The last couple years a problem has begun and has gotten worse. The stove will leak liquid fuel all over the base which then...
I have heard two things that could improve your stove. I had the same "bursting into flame" issue last weekend while camping. First, move the black handle back and forth a few times. That is supposed to clean the jet. Second, take the generator off and hit it with a blowtorch. That should clean out the deposites on the inside. Or you can purchase new generators (just make sure you get the correct one).
Aug 03, 2008 | Kitchen Ranges
Broken pump plunger / colman 426e
this site has all the parts you could ever want
http://www.oldtownyucca.com/coleman/parts/413.htm
Jul 03, 2008 | Coleman Campfire Grill
Kitchen Ranges Logo
290 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
