Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool side/side ice dispencer not working
Ice dispencer not working everthing else seems to be okay
some frost buildup on ice chute and front of ice container
I had the same problem, however, the ONLY fix was to call the repair guy and get a new part. I took it out, defrosted the unit thinking ice was in the gear mechanism, lubricated and re-installed it to no avail. The repair guy had SEVERAL of these geared mechanisms in his truck so that told me THIS HAPPENS A LOT. Good luck.
Posted on Aug 16, 2008
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost buildup on area where ice comes out of the ice bin with frost also on the inside of door chute
The flap door where ice is dispensed is warped letting warm air into the freezer causing the frost build up. You must replace the flapper - a $5 - $7 part but not too difficult to replace. I find the flapper last only about 2 years and frost problem reappears. Forget about a "weak heater".
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Whirlpool side by side ice maker freezes up. can't get ice out of
Can you give more details?
If the ice chute is frosting up, chute door is not sealing, air , with moisture, is getting in and freezing. An ice cube getting trapped by the door will cause this also. Either case, replace door and delay mechanism.
May 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker frosts over on the chute
This would indicate a problem with the ice chute door seal. Have it serviced. Air leakage would cause the frost-ice buildup.
Jun 01, 2008 | Whirlpool ED2FHSS Side by Side...
Frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Dec 31, 2007 | Whirlpool GS6NBEXR Side by Side...
Ice Jam in Chute - Whirlpool IDI SxS
first check would be to see if the flapper door is closing all the way in the dispenser area. best way is to remove the ice bucket and shine a flashlight from the front up into the disp door area and look for light around the door from inside the chute.
another check would be to make sure the door delay mechanism is connected an not allowing the dispenser door to close to fast trapping a cubes in the door and causing an air leak in the chute..
Keep in mind if you use alot of crushed ice frost build up is faster than with just cubed.
Dec 10, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
144 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
