Question about Kenwood Audio Players & Recorders
I have a kenwood kc-992 home stereo amplifier and the volumes stuck on high and the volume dial is doing nothing. is there any easy solution to fixing this problem without going to a shop?
I was wondering id you would be willing to sell your control amplifier? if you are interested please contact me at marge227@hotmail.com thank you for your time!!!
Posted on Jan 29, 2009
How can i hook up my kenwood stereo control amplifier KC-105 to my GPX home stereo system?
If the GPX has an headphone output you could use the a stereo headphone jack to two phono cables lead. Connect them to the "aux" socket of the amp, or another suitable - not a phono or deck - socket.
You would have to keep the volume level low on the GPX unit, but apart from that all the functions should work.
Aug 04, 2015 | Kenwood Audio Players & Recorders
I have a Kenwood KC 105 preamp and the volume is stuck on high. I turn the volume knob but it does nothing. Any suggestions?
Looks like you are going to have to replace the potentiometer, AKA volume control. It must be shorted out inside (probably) or knob came off the shaft. (doubtful)
Feb 02, 2015 | Kenwood Sc-75 Av Surround Processor...
Can i get a virtual remote control anywhere for my kenwood stereo control amplifier kc-209
The first place to start looking for them is in the Kenwood website. Perhaps they may have a dozen of so working remotes for you. Give them an email and see if they can help you. I had a roller door garage and after 4 years of use, their cheap little remote stopped working. I emailed their website and they had a few in a spare box. Guess what? They gave me two for nothing. Kenwood could do that too. All it takes is hit on the website and email them. Cheer
Dec 12, 2014 | Kenwood Kc 209 Stereo Control Amplifier...
Kenwood km-994 is to loud when volume dial is on low and will blow speakers if I turn it up
I'm no sure what you're asking. Do you mean that it goes directly from low to high immediately when you turn the dial(I'm assuming it has a dial, I haven't looked it up) or push the up or down button?
Answer is, if rotary, a bad rotary switch, or in both cases, a bad microprocessor or electronic volume.
May 02, 2012 | Kenwood Audio Players & Recorders
I have a 2001 chrysler voyager installed a kenwood stereo and when i raise the volume to where its lound the radio will turn off and on untill i lower the vol
My electronics savvy source says you may be overdriving the amplifier in your Kenwood stereo to an impedance-mismatched set of speakers, meaning that the speakers are impedance mis-matched to the Kenwood stereo, and therefore operate ok (but inefficiently) at low volume, but cut off completely at higher volume.
Fix: match the impedance of your speaker network to the specs on your Kenwood car stereo. Once this is done, you should be able to crank up the volume to the point of permanent hearing loss.
SAFETY CAUTION - sound levels above 85 decibels produce NIHL (noise-induced hearing loss).
http://www.dangerousdecibels.org/education/information-center/faq/
Oct 18, 2011 | Kenwood Car Audio & Video
I am connecting an amplifier to my VR-407 to accomodate more speakers I have installed throughout my home. Where do I connect the amplifier?
Connect the amplifier input to the VR-407 using the receiver's REC OUT jacks for the MD/TAPE input on the back panel. This is a fixed line-level output for recording, and will work fine for driving the additional amp.
Jan 17, 2011 | Kenwood VR-407 Receiver
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
I found this thread when I was having the same problem with mine. Turns out that it's sort of a problem, but not really. Looking at the manual (which I found in another google search) I believe a "4" on the volume level corresponds to a default remote control setting. The remote varies the level between 0 and 10, but the "10" corresponds to the maximum volume setting on the preamp. So it actually works, it's just that the "4" reading doesn't change. There's probably a pin you can short somewhere to make that default to "10" which would be ideal. But I'm not sure where that is. Now on to my other problem. This particular preamp has a subtle 120 Hz hum...
Nov 15, 2008 | JVC RX-E100 5-Channel Amplifier
Kenwood installation manual help?
Click HERE for Kenwood support and manuals.
May 15, 2008 | Kenwood Audio Players & Recorders
416 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
