Question about Euro-Pro Shark GI490 Iron
Iron won't heat
I turn on the iron (G1490), the temperature setting lights on the left go up as usual. But the iron won't heat and the green light at the bottom right flashes.
Any suggestions?
Thanks,
Bob Tolar
bobtolar@gmail.com
  • 2 more comments
  • Anonymous Aug 18, 2008
    retractable cord iis loose
  • Anonymous Mar 17, 2014
    All lights flashing but no heat on my swan iron s1503
  • Anonymous Mar 22, 2014
    iron not heating up. flashing light and beeping
    iron not heating up. light flashing and beeping
Send me manual on iron g1490
john reilly, 5640 hwy 14 w janesville wi 53548
asap
thank you
Posted on Oct 28, 2008
Shark iron g1462
the lights you witness are correct. once the iron has reached tempreture.
ensure the iron is stored in an upright position between ironing items if left laying down the iron may switch off as an anti-burn or fire safety feature as if left unattended. with the iron placed on its back plate with its point facing upwards the iron should stay on.
I hope this was useful.
May 14, 2014 | Irons
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
My iron lights up. when i set the heat choice the green lights on the right flash and it does not heat up
Generally, the lights on the right flash until the desired temperature is reached. When they stop flashing it means the iron has heated to the temp. that you selected. I'm having trouble with mine now, also, so I can't diagnose.
Apr 28, 2010 | Euro-Pro Shark GI490 Iron
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Iron will not turn on
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jan 27, 2010 | Euro-Pro G1490 Continuous Iron
Shark model G1490 won't heat. Can heating element be bad?
if lights are coming on its either the wire that send power to the heating element or the element itself
Jul 15, 2009 | Euro-Pro Shark GI490 Iron
I have a brand new Shark G1490. When I plug it the light turns on, but it does not get hot and besides this brown water comes out. what should I do? please help me.
push button down on top of iron to turn on iron and adjust settings and do a self clean to remove debris and scale build up from iron
Jun 11, 2009 | Euro-Pro Shark GI490 Iron
My G1490 Shark Iron will not heat up.
your heating coil probally went bad its alot cheaper tp just buy a new iron
Jan 18, 2009 | Euro-Pro Shark GI490 Iron
Shark G1490 doesn't light up or heat up when I plug it in.
circuit board has shorted out that control iron functions or power wire lead has broke off inside of iron
Jan 12, 2009 | Euro-Pro Shark GI490 Iron
Shark Euro-Pro G1490
Our G1490 quit after one year. Just won't come on. Period. I can't get it to open after removing the back screws either.
Jan 08, 2008 | Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI490 Iron Logo
913 people viewed this question
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
