Question about Uniden DECT1080-2 Phone
Recording a message
How do I change the message? i went to am operations it said record memo.... i recorded then, it said press 9 ot stop message. I did. The default recording still plays.
    Scholar:
  • 47 Answers
You need to record the OGM message not the memo. Memo is used for just that. You can leave a memo for your other half, child, etc.
The OGM is what callers here when getting your answering machine.
Posted on Jan 12, 2009
We don't know how to retrieve out messages from outside the house.
To play back messages remotely, first you'll need to have set up your two-digit security code (PIN). You can download a copy of the manual here which gives all the details. Once you've done that, here's how to use the system:
1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds. The answering system announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
3) Enter a command within 15 seconds. Each command thereafter must be entered within 2 seconds. These are the available commands:
  • 0 then 1 Repeat a Message*
  • 0 then 2 Playing incoming Messages
  • 0 then 3 Skipping a Message
  • 0 then 4 Deleting a Message
  • 0 then 5 Stop Operation
  • 0 then 6 Answering System On
  • 0 then 7 Memo Record/Stop**
  • 0 then 8 Greeting Message Record/Stop**
  • 0 then 9 Answer System Off
  • 1 then 0 Help
* For the Repeat a Message function, press 0 then 1 within about four seconds to repeat the previous message, or press 0 then 1 after about four seconds to repeat the current message.
**For the Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, press 0 then 7, 8 or 5.
4) After the command has finished, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart above.
5) Hang up when you're done.
Jul 05, 2011 | Uniden TRU8885 Digital Answering Machine
Tip
How do i send a voice memo with my blackberry 8830?
The BlackBerry 8830 smart phone, and other BlackBerry phones, come with an application to record voice memos called "Voice Notes Recorder." From this application you can create, store and send voice memos directly from your phone. You do not need to upload the memo on the computer or send it through email (unless the recipient cannot receive multimedia messages).<span><br /></span><br /> <span> <span>Instructions</span> <ol> <li><span>Open "Voice Notes Recorder" on your phone.</span></li> <li><span></span><span>Press the trackball to record the voice memo. Press it again to stop recording.</span></li> <li><span></span><span>Scroll to and select the mail icon while the memo is stopped.</span></li> <li><span></span><span>Select "Send as MMS."</span></li> <li><span></span><span>Choose the contact from the list, or choose "Use Once" and type the phone number of the recipient.</span></li> <li><span></span><span>Add a note to the message if you wish.</span></li> <li><span></span><span>Press the "Menu" button and select "Send" to send the voice memo and message.</span></li></ol></span>
on Mar 12, 2011 | Cell Phones
How do i get messages from remote location
To use your system from a remote telephone, you must first enter a 3-digit remote operation security code. The security code label is located on the bottom of the system.
1. Dial your phone number.
2. When your outgoing message is playing, enter your remote operation security code. Bd appears on the display to indicate the system is in remote mode.
If there are no new messages, you hear three beeps.
These are the remote codes available to you:
2 # Play all messages.
2 5 Play new messages.
3 # Delete all old messages.
7 # Record new outgoing message.
7 # Stop recording outgoing message.
8 # Record memo.
8 # Stop recording memo.
9 # Turn system off/on.
0 # Monitor the room..
Jun 12, 2011 | Radio Shack 3822 Digital Answering Machine
How do I access messages when I am not by the phone?
nschutz,
Remote Operation
You can operate your answering system from a remote location (when you are away from home, or from another room using a handset).
Use this function to check for recorded messages, to play or delete message. When using any touch-tone telephone, you can even record a new greeting message.
Remote Access away from Home
You can operate your answering system from a remote location using any touch-tone telephone.
1) Call your telephone number.
2) During the greeting message, press 0 and enter your PIN code
3) The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two.
For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
*For Memo Record and Greeting Message Record function, the first time you enter the corresponding command, it starts the Recording function. If you want to stop the recording, enter the command again.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering system automatically returns to standby.
0 then 2 Play Incoming Messages
0 then 3 Skip a Message
0 then 4 Delete a Message 0 then 9 Answering System Off
1 then 0 Voice Prompts
Turn on the Answering System Remotely
If you have forgotten to turn on your answering system, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press 0 and then enter your PIN code. The answering system announces the number of messages stored in memory. You hear "To play incoming messages, press zero two. For help, press one zero."
4) Press 0 then 6 to turn the answering system on. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Respectfully,
Adam04
Feb 28, 2011 | Uniden Cordless Phone EXAI985
I have a Uniden cordless answer machine,Can my meesages be retived?
You can operate your answering system from a remote location using any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even to record a new greeting message.
  1. Call your telephone number.
  2. During the greeting message, press 0 and enter your PIN code. By default, the pin code is "80" without the quotes.
  3. The answering system announces the current time and the number of messages stored in memory. Then you hear "To play incoming messages, press zero two. For help, press one zero".
Available commands are:
  • 0 then 2 Playing Incoming Messages
  • 1 then 0 Help Guidance
Jan 23, 2011 | Office Equipment & Supplies
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me,...
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
Oct 17, 2009 | Vtech Two Line Digital Answering Machine...
Binatone e920 quad phone with answer phone - can't record ogm.
Have had the same issue with a single handset. Finally located our manual:
1. Press and hold MEMO (FAST FORWARD) button until you hear a beep.
2. Record your memo, speaking from approx 15cm away.
3. As soon as you have finished speaking, press ON-OFF/STOP button to stop recording.
Hope this helps :)
Aug 13, 2009 | Lands Phones
I have a code for my Uniden cordless to get voice mail while away from home. Not sure what else I need beside the code.
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
5) After the command has finished, you hear intermittent beeps indicating that the
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
Jul 09, 2009 | Uniden Cordless Telephone
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
NEED TO RECORD NEW ANSWERPHONE MESSAGE ON ONETEL OT150
To record a new OGM, on the Onetel OT150
Press "menu" on the base unit, then "up" once to record OGM 1 or twice to record OGM 2.
Press "OK" The existing OGM will begin to play. Whilst this is playing press and hold "MEMO"
Record your message, speaking close to the base unit. Press "stop" (square) when finished.
If you decided you don't like your message then, repeat the process above but when it tells you to record your own message press "stop" (Square) and the default will be reset.
Jun 11, 2008 | Cable_and_wireless CWD4901 Cordless...
Uniden DECT1080-2 Phone Logo
146 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
