I have a mitsubishi tv need to find a deflection york (coil) prt#330p181040 can u help me
  • 8,617 Answers
I would need the model number of your set in order to help you find a replacement, as they are discontinued by mitsubishi. Please respond to this same post with your model number and I will try an assist you.
Posted on Aug 13, 2008
I have a Mitsubishi ws-65809, the tv won't power
I presume you unplugged the set and redid the check:
2,3 is deflection circuit problem (probably in Horizontal sweep circuit) and can be almost anything---check output transistors and look for cracked or bad cap in that area.
The error code is only a general indication of the kind of problem and this one is like saying car will not start etc.
Mar 18, 2012 | Mitsubishi Televison & Video
Deflect power supply
PCB Power has the Deflection Power Supply onboard and has a list price of $215.50 + S/H
Nov 10, 2008 | Mitsubishi WS-55313 55" Rear Projection...
I need a new deflection module for a Mitsubishi TV model no. WS-48311. Where can I purchase the part and is it easy to replace?
Why do you feel that you need a new deflection module? I can assist you in finding one but i would hate to have you order a part that you done necessarily need. Let me know whats wrong with the set and i will help!
Tim Nolan
Sep 24, 2008 | Televison & Video
Vertical deflection went out and now HV is going into shutdown
Get service manual / schematics from HERE and find why vertical uotput IC is blown in your TV.
Service Manual will also give you info how to perform vertical adjustments.
Hope this info will help you to resolve problem.
Aug 22, 2008 | Mitsubishi CK-31304 TV
WS-65903 HD1080
press format key on mitsubishi remote control and try to get full screen.let meknow if it works if not do you have a cable or satellite box and what type?
Jul 04, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Screen Smaller on Orion1934" TV
Hello Falken94,
Your TV is losing what is called vertical deflection. This might be caused by the vertical coupling capacitor going bad, or by the vertical deflection coil on the yoke transformer going bad. In any case there is not enough vertical deflection signal getting for the vertical output section of your TV to the vertical coils on the yoke transformer. I would suggest that you get this looked at by a qualified TV technician, due to the nature of this problem.
I hope this helps,
Thank you,
Shuttle83
Jun 19, 2008 | Orion1934 19" TV
Mitsibishi vs60707
This a deflection problem. Both 2-3 and 2-4 are deflection. Most likely a verticale problem. a tech will need to fix it.
Mar 15, 2008 | Mitsubishi VS-60707 60" Rear Projection...
TV - only single, linear image with sound
vertical line on the screen is due to problem in horizontal deflection coil circuit
plz check
  • connector loose which is going to deflection coil mounted on crt.
  • loose contact or print break from flyback to def.coil.
  • capacitor defective going to deflection circuit.
  • if you are not tech person call tech. to fix it
  • it is not a major problem & can be fixed at your home.
  • hope this will help.
  • good luck.
Oct 17, 2007 | Televison & Video
Have sound but no picture
solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Jul 07, 2007 | Mitsubishi VS-4544 45" TV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
