Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Smelly refrigerator I recently had maintenance come to fix a problem with my fuse box in which he had to turn off the power to the house. After that, I noticed a horrible smell, almost like a mix of bad body odor and spoiled milk. After cleaning my kitchen several times, I noticed that the smell was located at the frigde. After pulling it out, it seems to be coming from the back of the unit.
  • Anonymous Sep 01, 2008
    Wash with soap & water,vinagar and used baking soda. It smells like over ripe brocolli.
  • 1,800 Answers
HI.
i guess u will benifit from this link
plz rate this post
click here
BEST REGARDS
Posted on Sep 02, 2008
On base board heater how do you know when its off
Depending on what you are trying to achieve.
A) Normal operation, and unit shuts off due to reaching its setpoint. On some heaters there is an indicator light that turns on when the thermostatic switch turns the element on.
B) Maintenance mode, to shut off power before servicing. Turn off circuit breaker or fuse at house fuse panel or Breaker box. Check with an electric meter(Volt Meter) that the elements are not live. (Should be 0 volts across mains).
May 03, 2014 | Heating & Cooling
My toyota Highlander is showing CHECK VSC light
First check and make sure your gas cap is tight, if this does not resolve the problem read below.A vacuum hose has become disconnected, more than likely due to having your air filter replaced. The VSC and Check engine light typically don't come on until after 150-200 miles after the vacuum hose was pulled out The fix: on the right-hand-side of the engine compartment behind the big plastic housing that holds the air filter you will find a black rubber hose that is not connected to anything. Squeeze the finger clamp on the hose and slide the hose back onto the half inch nipple on the back of the air filter's plastic housing In order for the VSC and Check engine light to be turned off, you will need to open the fuse box, right-side of the engine compartment, and pull the 20 amp EFI fuse for 10 seconds. This will reset the system. The fuse location is marked on the lid of the fuse box, also I believe the EFI fuse is the only 20 amp fuse.(and after you're sure nothing is really wrong with your car), try resetting the "maintenance required" display by setting first your ODO display to the ODO setting. Turn off your engine. While pressing and holding down the ODO button, turn your key to the ON position. The display will do this weird blinking action then it'll go back the ODO reading. No more "maintenance required" display.
Oct 11, 2011 | 2008 Toyota Highlander
We recently moved. Ever since the move, the dryer has not been working properly. It turns and dries clothes but not fully. Even at its highest temperature and very dry mode, the clothes still come out...
What you need to check is if the venting the dryer connects to is crushed/restricted or in some manner blocked. Check from where it connects at back of dryer all the way to where is vents outside of the house.
Gene
Aug 16, 2011 | Samsung DV448AGE Gas Dryer
HI, I have a Whirlpool Side-By-Side Refrigerator model ED25PQXW01 and the ice maker isn't working, how do I fix it??
Hi
Check to see that the refrigerator has power and is working. Reset or replace the fuse or circuit breaker in the house if needed, especially if a power outage has recently occurred. Make sure the water valve is connected to the refrigerator and is fully turned on. Ensure that the ice maker is turned on. Some Whirlpool refrigerator models have a switch located above the ice bin; some models have an arm that should be raised up to turn the ice maker on. The arm is also located above the ice bin. Clear away any ice cubes that may have gotten jammed in the ice maker, bin or dispenser that may be preventing ice cubes from moving as expected in the system. Use a plastic utensil to clear away any obstructions. Contact an authorized service center for assistance if the above steps do not fix the issue.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Whirlpool 25.2 cu. ft. Side-by-Side...
Blown Fuse
Find the main braker to the house. Pull it out, or flip it off. It's probubly right above the fuse. Plug some thing in several outlets, to make sure all power is off. Then use a pare of needle nose pliers, to get the fuse out. Make sure all power is turned off to the house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jul 04, 2010 | LG 22.4 Cu. Ft. Side-by-Side Refrigerator...
Refrigerator not cooling
No, the compressor does not have a manual reset switch on it. The first thing to do would be to check the breaker or fuse box. Make sure everything is on. Then with a voltmeter, check the wall outlet to make sure you have power. If you do have power and the refrigerator isn't turning on at all, you may have to have someone with electrical experience take a look at it.
Apr 02, 2010 | Frigidaire FRS26R4A Side by Side...
99 Corolla power windows not working
If all have failed I'd suggest checking the car fuses.
Mar 16, 2010 | 1999 Toyota Corolla
Second hand Fisher & Paykel keeps tripping power off
sound's like you have dead short to ground in the start mode of the compresser.
Nov 22, 2009 | Maytag MSD2651 HE Side by Side...
Does anyone know about fuses. I have a 1993 cbr900rr. It has 5 fuses in the fuse box. Does anyone know if there is other fuses in another location?? Or is that it?? Thanks
sorry that didnt help...i found my 30amp fuse connected right into the starter relay...the fuses look just like the usual ones....on my old 87 cbr it is located under right hand cover..close or near to battery housing...follow the red wire to see where it runs off to. On my bike the fist thing it runs into is the starter relay with a nice big 30ampere fuse on it....i havent worked to see if their are others because i went through my print and thats seems to be it. Can you describe your exact starting propblem...i my be able to suggest a few things....need recent maintenance reports! later and hope to get it running.
Sep 24, 2009 | 1993 Honda CBR 900 RR Fireblade
Smelly toyo stove
There is a medium rubber hose (baffle) on the bottom of the unit (inside) that may have dried up and it's not venting correctly.
Apr 26, 2008 | Grilling
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
90 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
