Question about Westinghouse 78500 Casanova White Ceiling Fan
Westinghouse ceiling fan with 3 lights ( not sure of model)
When swiitch on the lights the bulbs pulse but do not stay lit. The fan does not turn when switched on at the fan or when operated by the remote. Can you help please with a diagnosis orf the problem and a possible solution/
Thank you
    Problem Solver:
  • 5 Answers
Maybe a bad remote module in the fan
Posted on Aug 14, 2008
How do I connect a 3 bulb light kit to my 30 ceiling fan?
as the wires for the lights come down through the shaft around which the fan spins and have to be connected to a separate light switch , this really is a job for an accredited electrician
Nov 10, 2015 | Westinghouse Dryers
Westinghouse ETL-ES-TurboSwirl-MN-WH09 ceiling fan glass globe part#
There is a chance is says on another light bulb,a little tag with a number.
Mar 09, 2014 | Hunter 23852 Classic Original Ceiling Fan
Westinghouse ceiling fan light kit
Make sure the light wire coming out of the TOP of the fan is connected to the hot wire in the ceiling.
Aug 03, 2013 | Dryers
Light switch by westinghouse 77020
Copy following link for general assistance wiring 4-wire ceiling fan switch:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Jul 16, 2012 | Westinghouse Electric Ceiling Fan 3-way...
I have a hampton bay ceiling fan. I put cfl bulbs in the lights and when i turn the lights off using the remote the bulbs continue to flicker. when i turn the wall switch off the bulbs stop flickering. the...
The problem is that the CFL lamps, once they are lit, will stay energized by a very low level of current, and the remote obviously is not what we would call a positive off device .. if you use the wall switch and then go back to the remote in the off position , do the lights come on flickering again? You could try another brand of remote.
May 19, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
I have a ceiling fan with lights taht go on and off
I had a similar problem - the center terminal where the light bulb screw in became somewhat corroded. If you turn off the power, you can clean these with a small piece of fine sandpaper - then bend them slightly outward so that when the bulb is screwed in, they make good contact. If that doesn't work, and you have a voltmeter - check the voltage at each bulb socket to make sure the internal wiring is ok. Not to overstate the obvious - but make sure the bulbs are ok too....
Jul 21, 2009 | Emerson Fans CF770BC Monterey Ceiling
I need a capacitor for a ceiling fan model # cd-52
You can go to Radio Shack take the old one with you and you can replace it yourself or you can google your model fan, and make and they will help you Remember ask a question of google like where can I find a capacitor for a Westinghouse etc....
Jul 09, 2009 | Westinghouse Electric Ceiling Fan 3-way...
Westinghouse 78500 Casanova White Ceiling Fan Logo
244 people viewed this question
Top Westinghouse Dryers Experts
stevensmn
Level 1 Expert
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
