Question about Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Fuse blown Does this require a slo-blow or fast acting 6.3a/125v fuse?
  • dahinsoncoj Sep 15, 2008
    New fuse blows also. Help...
    Problem Solver:
  • 6 Answers
Hi mate most uk set have a 3,15amp 250v fuse ti dosent matter if its quick or slow all the best Bob
Posted on Aug 14, 2008
SOURCE:
Can power on
Check the fuses.Blown fuse conditions
FU1 - 6,3A Doors/covers open is displayed.
FU2 - 6,3A Doors/covers open for the finisher is displayed.
FU3 - 4A paper end condition.
FU4 - 6,3A SC 121 is displayed.
FU5 - 6,3A one of SC302 or SC403 or SC405 is displayed.
FU101 - 15A no response.
Fu 102 - 8A no response.
FU103 - 1A normal operation,optional heaters do not work.
If FU or 102 is the problem,verify the main motor and the fusing unit heater lamps and thermofuses.After change the problematic fuse removal the fusing unit and turn ON the copier.
Apr 18, 2013 | Ricoh Aficio 450 Copier
How do I know If the fuse that needs replaced is a "slow blow" or "fast acting" fuse?
Look at the stampin on the fuse, if it has TXXA 250V, then it is a slow blow fuse type (T = Time dealy), some may be stamped with SLO-BLO XXA 250V on it.
Post pictures if you are not sure.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 24, 2010 | Philips Televison & Video
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
NAD C270 amp won't switch from red power/protection to green.
The AH may denote "slo-blo" style as opposed to Fast-acting
A fast-acting fuse will look like a single strand of wire ( maybe wiggly looking) ..A Slo-blo will have an element in it and a spring
Apr 11, 2009 | NAD C270 2-Channel Amplifier
Oster wine cooler fuse
I just replaced mine with a "Slo Blow" and it is working just fine. Got it at Radio Shack , 4 for approximately $3.
Sep 25, 2008 | Oster 12-Bottle Wine Cellar - Black
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
Z-5300 blown fuse
When fuses blow theres a problem, now how it blows help you find out where the problem is, If the fuse flashes and turns black the second you turn it on or plug it in there is a massive short in the power supply, If it blows but is clear the surge was not a dead short but a overload, Either way best to run it down to the shop and get it looked at
Feb 14, 2008 | Logitech Z-5300e Surround Sound System...
Denon PMA 520 fuse blown
Check that you are replacing the fuse with the correct type first. Fuses marked with a T following the rating are "slo blo" fuses and if a fast blow is used instead, it will fail again at turn on. Otherwise, the amp will have a fault occurring, probably in the output stages. You should refer this type of fault to a repair guy that knows HiFi. as this sort of repair needs an experienced touch.
Jan 05, 2008 | Audio Players & Recorders
Blown Fuse, needs fix'n
You CAN open the unit (keep in mind that even unpluged there is still voltage runing through the system, so.... dont fry) and you will notice, if the face of the unit is towards you you will see on the left hand side a power supply board, the fuse is on that board, and it is a tube fuse, 125V 8A. Most stores do not carry the 125V version anymore, but will carry a 250V. This is okay to use where the voltage is not the main purpose of the fuse.
Oct 19, 2007 | Onkyo HTR500 Receiver
Toshiba MW24FP1 24 in. TV/VCR/DVD Combo Logo
118 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
