Question about MSI Computers & Internet
Router I have entered a wep on the msi router but have forgotten the password. Can you asist to reset so I may record another passord?
    Problem Solver:
  • 18 Answers
There should be a reset button on the back of the router. (most have it.) Hold the button for 10, 15, or 30 seconds (depends on router.) until you see that all the lights blink and go off. It SHOULD reset all the settings.
if not make sure you held the button all the way, cause otherwise it'll just do a soft-reset and not bring back the settings.
Posted on Aug 14, 2008
Need wep key
Access the management page from your browser. (Internet Explorer, Firefox, Etc.)
The address is: 192.168.1.1
The default password is admin, leave the username blank
Click on the "Wireless " link
Then click on "Security"
You will see your WEP key there.
If you have forgotten your router passsword, you will need to reset the router.
Linksys reset
The easiest method of resetting your Linksys router's password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password "admin", in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to "admin" on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 27, 2011 | Linksys Wireless-G WRT54G Router
We have forgotten our password to our router - it is a WEP # - can we reset the router??
The router password gets you into the utility program--the WEP password is the SSID allowing you to connect (wirelessly) to the router
Open INTERNET EXPLORER and. (In the URL address field), enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for passsword.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.
OR YES YOU CAN ALWAYS RESET TO THE "OUT-OF THE BOX" SETTINGS BY PRESSING THE TINY RESET BUTTON ON THE BACK (need paper-clip)
Jan 12, 2011 | NetGear RangeMax WPN824 Wireless Router...
Hi I have a MSI RG54G3 ROUTER could someone tel me where the WEP number is or where can i obtain one Please can you help
Take an Ethernet cable, and connect one computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Look for a line of output like:
Default Gateway . . . . . . . . . : 264.468.326.124
Start Internet Explorer
Type http://264.468.326.124 and press ENTER
Login to the Router (ID/password required)
Run the Wireless Networking Setup Wizard,
and create an SSID and create a WEP-key.
Jan 25, 2010 | MSI Wireless-G RG54G3 Router
Can't remember password for my router and need it to get on the internet with another device with my linksys
You can accsess the router config menu by using your browser. Type in 192.168.0.1 or 192.168.1.1 into your browser. That will bring the screen up to enter your user name and password. If you have not changed it the default is username:blank(no entry) and password is:"admin". If you have forgotten this password then you will need to use a pen to push and hold the reset button for more than 4 seconds to re-set the password to the default(this will clear all the router settings to factory default and disable WEP/WPA settings). Once in the router config menu you can then look at/change the WEP or WPA security key that every computer needs to connect to the router.
Dec 28, 2009 | Linksys Wireless-G Broadband Router
My network says that it can't find the internal wireless adapter
well! friend i use to work for netgear and let me tell you if your wireless network was unsecured then somebody connected to your router wirelessly and enabled password on your router.it is quite possible that your router login password is also changed.if not then you are lucky.try this ->
goto start - run - type CMD and press enter in the DOS window type ipconfig and enter whatever is the default gateway is just copy it.open inter explorer and type that default gateway in the address bar and enter.it will ask you for username and password.use the username and password provided on the back the router on the sticker.get into your router`s settings goto wireless section and change the password.it would be WEP or WPA.always keep security or that guy will hack your wireless again. if it doesn`t work then you have to reset the router by pressing the little button on the back for 10 to 15 seconds.reconfigure your router with the help of the CD that came with it you can also do it manually if you know.
Jun 01, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
AirPlus Extreme Wireless G Router-Can't reset Username/Password
on this router, leave the username blank and enter admin in the password box.
Apr 18, 2009 | Linksys Wireless-G Broadband Router
Forgot network password
Hello...if you need to retrieve your network key, eg to connect a new laptop to the internet, this can be found within your router settings.
Here's a rough guide:
1. Type your router IP address, eg http://192.168.1.1 or whatever is correct for your model, into a web browser address bar
2. Enter your router username and/or password at the prompt. The defaults for Linksys are username: (left blank) and password: admin : but if you have set a router password/username, please enter these.
3. In the router user interface, go to the section headed Wireless Security, or similar. Every router is different, so you may have to hunt around a little. Key words to look for are Security, Wireless Settings, Encryption, WPA, (or WEP).
Your network key will be somewhere here. It might be labelled PSK, pre-shared key, WPA or WEP key, WPA-PSK, network key, WPA shared key, passphrase etc – but that’s the one you need.
For more details, you could pick up a manual from the Linksys site or view the help pages; otherwise, please come back to Fixya with your model number, and let us know how we can help. Good luck
Jan 23, 2009 | Linksys Wireless-G Broadband Router
I've lost my wep password
yes..that will revert it to the default admin settings..usually...
May 07, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Computers & Internet Logo
48 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
