Question about Whirlpool Microwave Ovens
27 day old unit - turn table will not turn. - Whirlpool Microwave Ovens
  • Whirlpool Master
  • 8,865 Answers
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free. Whirlpool customer service is here.
For owners whose oven is out of warranty, read on:
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel (and your model does not have this feature) but it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 18, 2008
Size of glass turn table for a whirlpool vip 27 microwave oven
Could be a fairly common part. Check with a local appliance parts supplier.
Aug 08, 2016 | Whirlpool Microwave Ovens
Turn table won't turn on ewave microwave oven
Almost certain if microwave still heats a bad motor or gear issue inside the unit--if unit will not heat the safety switch in the side that the door engages is the cause of the wheel or platter not turning--prevents unit from use if door open.
Nov 06, 2012 | Microwave Ovens
The turn table stopped turning and the unit stopped heating.
the turn table stopped and the unit stopped heating.What should I do?
May 30, 2011 | Goldstar MV-1501 Microwave Oven
Turntable in microwave does not turn. is it dangerous to keep using it?
hi. ther is no problem using your micro with the table not turning. as long as it still heats. the turn table is usually the first to go. i have had a couple like that and used them for a long time with no problems. you should be fine. hope this helps ease your mind. have a good day!
Jan 15, 2011 | Microwave Ovens
Turn table does not turn when heating. Interior light does not come on during cooking, works fine when door is opens.
some microwave is have PCB control if pcs is shorted some parts light bult,fan or syncronus motor is on mode we need to replace the pcb but some problem is only is micro switch,if mocro swict is rusty or corroded that the time not working the turn table,but you said every time open the door the ligth is ok,if the turn table also running during open door have problem in your pcb board that we need for replacement,but check the price of parts and make it desicion if you want to repair or buy a new one if your unit is very old.
Dec 28, 2010 | Microwave Ovens
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Keeps running
interlock switches.. more than likely it is the monitor switch in the middle that needs to be replaced
Mar 17, 2009 | Microwave Ovens
No heating or power to microwave oven
You have a fuse in the back that's problem is blown
Mar 13, 2009 | Microwave Ovens
27 day old MH1160XSQ micro-wave- turn table will not turn.
Aug 13, 2008 | Whirlpool Microwave Ovens
I have a combi which I have had for some years model carousel1 and the turn table has become slow and at times stops I have purchased another sharp--delivered yesterday modelR-959M-but if the old model...
if you open it you will see a large belt that connects the table ,
it might be stretched or greasy. remove it and turn the table by hand . is it sticky or turns easy . gunk can be in the bearing surface.
Apr 25, 2008 | Microwave Ovens
Microwave Ovens Logo
26 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
