Question about Ovens
Decor oven I have a dacor convection oven model # cps127.  No heat.   I'll set the temp to 350, it shows a temp of 135 and after approximately 7 seconds I hear a click and then another click.  The boat is dead in the water.
  • 1 more comment
  • Ted Bailie Jan 22, 2009
    I have the same problem as another person. My Dacor Oven will not heat up. I set the oven for 375, and then it goes to 135. It does not heat up. I have been told that it is the Heat Sensor in the controls. The sensor has been tripped and needs to be reset. How do you do this?
    Does anyone know?
  • Anonymous Apr 09, 2009
    My oven is having the same problem. Still looking for solution outside of calling the repair service
  • Anonymous May 20, 2009
    we have the same problem as 'superman4u2' with our Dacor double ovens...happens when oven door is left open to long and trips the sensor.
I have a dacor oven and I have the same problem. I called the Manufacture and they said it was due to the Heat Sensor in the panel. The Sensor has been tripped and needs to be reset. Now I am in the process of finding out how to get into the panel.
Posted on Jan 22, 2009
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Dacor 1.5 years old convection oven...not heating
Flip both oven breakers HARD to the "off" position, then back on. If it did not help - you might have a problem with a relay on the control board or a failed bake element.
Grab a flashlight and check the element on the bottom (if you can see it). DO NOT TOUCH THE ELEMENT! If you find any bulging or cracking on the element - it'd out. Before removing the element turn the oven off on the breaker panel.
PS Model number is needed to find the part numbers.
Oct 22, 2009 | Ovens
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dacor CPO130W F4 fault
f-4 on decor ovens mean the oven temp sensor is bad. replace the oven temp sensor and it will be fine
Nov 27, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
Dacor convection oven cps127/130 failure code f1
i found my circuit/schematic tucked inside the back panel in a envelope, you have to remove the oven from the wall to gat to it and start un screwing the panels, i think it was on the top.
Sep 04, 2007 | Ovens
Ovens Logo
469 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
