Question about Whirlpool Microwave Ovens
27 day old MH1160XSQ micro-wave- turn table will not turn.
  • Whirlpool Master
  • 9,098 Answers
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free. Whirlpool customer service is here.
For owners whose oven is out of warranty, read on:
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel (and your model does not have this feature) but it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Posted on Aug 18, 2008
My microwave is working but the turn table is not turning
next time send the brand name and model number,when you go to work on a micro wave unplug it,even if you change a bulb on it,i've seen people change the bulb without unplugging it and cook the computer board,on the bottom there's a motor that turns thee turn table,drop the bottom panel of the micro wave usually like 6 to 9 screws and on some there could be an access panel just for the motor,unplug the old motor and remove screw or screws,pop off the cover inside the microwave where the glass turn table sits on and,put the new motor in and put it back the same way you took it apart,it's pretty easy to do.go here put your model number in and find part number
https://www.searspartsdirect.com/part-number/241700104/0046/253.html?pathTaken=partSearch&q=241700104
Jan 13, 2018 | Microwave Ovens
My microwave turns on but no heat and its not spinning
No heat --is a failed front electronic panel or
micro wave gun
No turn table-- is a broken belt under the cabinet
Aug 13, 2014 | Cuisinart CMW-200 Convection/Microwave...
GE micro wave oven turn table won't work Model LVM1750DM1BB, #SM900740B
first:check AC chord.,
2nd:check fuse,f fuse open check big capacitor.
3rd:check heating element if shorted replace it....hope it can help.
Sep 22, 2013 | GE Microwave Ovens
Ge profile micro wave above stove 1850SM2SS will not heat turn table works and lights work
If you know DMM then only you can fix it. Check magnetron continuity and the transformer continuity. Mostly magnetron blows up. Danger microwave has 5000 volts in it Thanks Discharge capacitors
Nov 13, 2011 | GE JVM1850 1000 Watts Microwave Oven
After closing door micro wave turn table continues to turn and light stays on after you open door and take out food.
The problem is most likely caused by a defective door switch, and should be rectified for safety reasons.
Apr 05, 2011 | Whirlpool WMH1162XVS Microwave Oven
MICRO WAVE IS NOT HEATING. Light works; table turns but not heat.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 14, 2010 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
98 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
