Question about Kidde Nighthawk Combo Gas/co Detector
Carbon monoxide detector err code
Hi: i have a kidde nighthawk carbon monoxide detector and it has an error code on it.....it keeps beeping every few minutes........dont have the manual........do you have any insight? thanks
  • 1 more comment
  • Anonymous Dec 12, 2008
    error code and keeps beeping...how do you fix it?
  • drsue33
    drsue33 Oct 07, 2012
    I got the ERR today hence my hunting around on the web to see what the problem is. Shame on the companies for forcing these detectors to have a shelf life. There is no reason for that and a rip off to consumers
  • Anonymous Mar 21, 2014
    Beeping every 30 seconds with ERR message
Detecotrs have a limited lifespan of 5-7 years. So sounds like you need new one (It's not worth to buy just a sensor). Take a look on amazon: Amazon com Carbon monoxide detector (watch out on reviews). I hope this was helpful. cheers
Posted on Nov 28, 2014
  • 5 Answers
You are going to hate this as much as I did!
In the manual you will read this ..
Manual for Kidde Nighthawk C02 Detector
On page 13
Unit Malfunction
In the rare event that your alarm malfunctions,
it will alert you with a short “chirp” and the red
LED will flash once every 30 seconds. The
digital model will display “Err” as shown in
Fig. 6.
Seven years after initial power up, this unit will "chirp" every
30 seconds to indicate that it is time to replace the alarm.
The unit will not detect CO in this condition. Please replace
immediately.
Posted on Dec 14, 2008
  • 3 more comments
  • Fishless Mar 02, 2011
    Are you saying that ALL carbon monoxide detectors have a built in auto fail device....nice if you're selling detectors....not so nice if you're buying them.
  • Ed Ledoux Dec 18, 2011
    @ Fishless: The sensor technology used in residential CO alarms is chemically-based, with a shelf-life that becomes less effective over time (typically 5-7 years I think). If it were available, you probably wouldn't want to pay for one that lasted longer
  • Joan Jun 26, 2013
    That really sucks. Both of mine started doing this within a couple of days of 1 another. I changed batteries and it did the same thing, so I thought the batteries were old. Then I bought new batteries. Thanks for the insight into this.
  • Lisa Groux
    Lisa Groux Mar 07, 2014
    Thank you for explaining. It's nice to know why. Nighthawk/Kidde should explain this error on the unit so the homeowner won't panic and call the fire dept.
  • Joan
    Joan Jun 04, 2014
    I agree. Who keeps a manual to something so inexpensive for 7 years? I keep most but didn't have this one. A note on the unit would make a lot of sense. Or let the message say "replace" instead of ERR. That tells you nothing
Kidde Nighthawk KN-COP-DP
I also got the ERR code this morning, with a beep every 30 seconds. I bought the device on October 1, 2001, and this happened on October 16, 2008. I called the manufacturer's toll-free number and was informed that the unit has a 5 year warranty and a 7 year lifetime, and that the unit needs to be replaced. I'm guessing that this error means that its lifetime is over.
Owner's Manual
-Ron
Posted on Oct 16, 2008
  • Karen Robinson
    Karen Robinson Oct 28, 2013
    Yep! Got mine in 2006...it's now 2013... It's beeping every 30 seconds. After running around like an idiot trying to figure out which smoke alarm was chirping, I finally saw the Err display and figured out it was the CO2 detector. Grrrr
Hi i have a kidde nighthawk carbon monoxide detector and it has an error code on it.....it keeps beeping every few minutes........dont have the manual What can I do
Thanks
Posted on Oct 07, 2008
I have two battery operated Kidde alarms which I purchased on the same date in 2003. One was manufactured October 14 2002 and the other was manufactured October 21 2002. On May 1 2010, BOTH ALARMS began chirping every 30 seconds, indicating alarm malfunction. As GeekinTexas suggested, the two units probably reached the end of their manufacturer-defined 7 year lifetime
Posted on May 02, 2010
  • 1 more comment
  • IamAlonaLee Nov 01, 2010
    I might have purchased mine 7 years ago.. but it spends the spring summer without batteries sitting in the closet.. so what??? It has an internal calendar that updates every time that new batteries are put into it??? so mine is really only 3.5 years old in usage.. so how do you define a "lifetime" ??? I think they need to check with Mr.Webster and offer a fix ...
  • reddawgesq
    reddawgesq Jan 31, 2011
    The 7 year clock starts ticking from the time the unit was "first powered up". It doesn't matter how long you have actually used it, with a battery in it or not. ANY operating time is apparently enough to charge an internal capacitor that will store enough power to keep the clock alive for 7 years. Then it enters its "planned obsolescence", er, "End-of-Life" mode; i.e., it's dead.
  • IWILLGET2It Feb 21, 2011
    I love this business model! My parents still have a fridge from 1964 - it still runs great...but then again - it was made in America.
Mfg date2005 april 3 goes to err
Posted on Mar 27, 2009
Apparently, the people who are saying that these things have 'reached end of life' are correct. I've managed to download the manual for my Nighthawk (wasn't the kiddie version) and it says amazingly that after 7 years it goes into 'auto-fail/replace' mode.
Which angers me severely because as long as it passes the internal checks, it should just keep on working forever.
Posted on Oct 05, 2012
  • abresh2
    abresh2 Oct 05, 2012
  • 5 Answers
All UL-listed detectors are required to have a hard-wired end-of-life alarm due to the limited lifetime of the detection sensor chemistry, to make sure people know when it can no longer protect them. It is not a business model, it's a safety issue. I found the UL requirement through Google; one doc is:
http://www.ncdoi.com/OSFM/Journal/Articles/2011/080411c.pdf
Posted on Oct 16, 2013
  • ExLibris Jan 28, 2018
    David said, "It is not a business model, it's a safety issue."
    And yet, Kidde's 10 year sealed lithium battery detectors (like the C3010) have a TEN YEAR sensor lifetime.
    The question should be why does Kidde use 7 YEAR lifespan sensors in detectors for which the user can replace the batteries and/or they are AC mains powered?
    Note: their low-end 10 YEAR sensor and "sealed lithium battery" CO alarm sells for just US$10 more than the comparable user battery supplied unit, so it seems there is insignificant Base Manufacturing Cost (BMC) difference between the 7 and 10 year SENSORS.
    I would certainly be willing to spend an extra $1 for a 10 Year sensor even if I still have to replace batteries. By the way, my 7 year sensor equipped CO alarm batteries never had to be replaced in the 7 year period...so I WOULD save considerable money if Kidde supplied 10 year sensors in those models...I would save OVER $100 overall instead of buying the more expensive "sealed lithium battery" models. It also saves on having added business costs every 10 years instead of 7 years (e.g. multiple alarm replacements).
    There is NO technical reason not to install a 10 YEAR SENSOR in all their models, and based on product pricing it looks like the BMC argument is insignicant or minimal.
    CHOICE...give the consumers meaningful choice. By that I mean Kidde should offer the 43% longer lasting 10 year lifespan CO sensor alarm whether or not it's the sealed lithium or user-replaceable battery version. That lets the user choose between sealed-battery or user-replaceable battery at a lower price-point while still getting the superior lifespan sensor technology.
    Personally, I also think Kidde should provide ONLY the 10 years lifespan sensors in ALL models because it is a virtual certainty someone will see the "10 year" specification in the sales literature for the sealed lithium battery models and think it applies to ALL models...potentially leading some users to mistakenly NOT replace their 7 year lifespan models when needed. Note that the ONLY place Kidde distinguishes the 7 year lifespan is BURIED deep in the user manuals for those models...and NOT in the sales literature (as far as I've seen).
    New Friend:
I had the same problem this mourning. Chriping blinking and err. So I got outthe manual and I wrote the date I bout it. 11-1998. So i guess 2012 now it has done its job. But all the manual said was to call there 800 number if this happened. So they can get you to purchase from them..
Posted on Nov 22, 2012
I have a nighthawk carbon monoxide alarm which is showing nan error code. Please can you tell me what to do to rectify it? Thank you.
You can unplug the unit if it's an AC detector, change the battery for a new one and reset the Carbon Monoxide Detector. If that doen't work, you can have it checked by your local fire department. If the unit is more than 5 years old, it absolutely needs to be replaced.
Whenever in doubt about the efficiency of a carbon monoxide detector, a replacement is recommended. Yes, protection has a price, but a life cannot be replaced.
Read more industry information, buy your next Carbon Monoxide Detector here.
Aug 06, 2010 | Kidde Nighthawk Combo Gas/co Detector
My Kidde Nighthawk Carbon Monoxide detector was beeping shrilly and read gas. When pressed the reset button it read 221. Problem was it was sitting facedown in a box (i'd just taken it from my old...
A reading of 221 ppm carbon monoxide gas is a dangerous level that should be taken seriously. You could try a new battery and reset the detector. If in doubt, always err on the cautious side and have the apartment checked by a professional or by the local fire department.
A new carbon monoxide detector is a small investment that may prevent carbon monoxide poisoning or death.
Jul 22, 2010 | Kidde Nighthawk Combo Gas/co Detector
How can I shut off my Kidde carbon monoxide detector when beeping
Here is the link to the manual for your Kidde model KN-COB-LCB-A
Carbon Monoxide Detector. This may help you solve your issue.
You may find more related information on my website. If you need a replacement or you need to add additional Carbon Monoxide Detectors in other levels of your house, you can purchase them here.
This issue should be solved immediately, Carbon Monoxide Poisoning can only be avoided by making sure you have good working CO Detectors in your house, camp or recreational vehicle.
Jul 24, 2010 | Kidde Nighthawk Combo Gas/co Detector
Error code keeps coming up on nighthawk carbon monoxide detector
An error code on a Carbon Monoxide Detector is a serious matter that should be looked at immediately. Your local fire department will be glad to help you with this issue.
If the error code keeps coming, it may mean that you have a defective unit. If the unit is new, you should be able to get a replacement where you boutht it. A unit that is more than 5 to 7 years old should be replaced, see manufacturer recommendations.
Browse my website for more information or for buying a replacement for a new Carbon Mononxide Detector.
Jul 16, 2010 | Kidde Nighthawk Combo Gas/co Detector
My nighthawk carbon monoxide alaram is keep biping
Check your user manual for issues dealing with beeping alarms.
Your local fire department may be able to help educate you on the proper installation and use of Carbon Monoxide Detectors. A CO detector alarm should be taken seriously and you should follow the manufacturer procedures included in the package.
NEVER dismiss a Carbon Monoxide Detector Alarm for a malfunction.
ALWAYS treat an alarm as an emergency and follow manufacturer procedures.
Check our website for more industry information or for buying replacement Carbon Monoxide Detectors.
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
Jun 27, 2010 | Kidde Nighthawk Combo Gas/co Detector
My carbon monoxide detector keeps beeping in spite of replacing thebattery and gives an error code of E09. Also it keeps flashing an err on the led redout. I placed it outside and it is still doing it...
Hopefully you have found a solution for your Carbon Monoxide Detector issue of October 4, 2009. The best solution for a questionable CO dectector is a replacement.
A Carbon Monoxide Detector is the only thing that will read, detect and sound an alert when reads dangerous levels of CO levels in your house. A defective carbon monoxide detector will give you and your family a false sense of security and will give you no protection.
Whenever in doubt, always err on the safe side and replace Carbon Monoxide Dectectors, your life depends on it.
View my website for related information and compare brands and models of Carbon Monoxide Detectors available for sale online.
Oct 04, 2009 | Kidde Nighthawk Combo Gas/co Detector
Kidde nighthawk Carbon Monoxide & Smoke Alarm single beeps
If detector is more then 5 years old it will beep every 30 seconde to wirn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Sep 21, 2009 | Kidde Nighthawk Combo Gas/co Detector
KIDDE Nighthawk Carbon Monoxide alarm beeping
If detector is more then 5 years old it will beep every 30 seconde to worn you the sensor in the detector needs to be replaced. bying a new detector would be better.
Jun 03, 2009 | Kidde Nighthawk Combo Gas/co Detector
Kidde Nighthawk Combo Gas/co Detector Logo
110,662 people viewed this question
Top Kidde Home Security Experts
john h
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
