Question about Bosch WFK 2401
WFK 2401 Whenever I run a load of wash that requires hot water, the water just keeps running until water runs out the front. The hot water will not turn off. Everything else works fine. I just turn the hot water off in the back and then there is not a problem. The water runs even if I turn off the machine. What can I do?
  • ctmanuel Oct 31, 2008
    Whenever I run a load of wash the water just keeps running until water runs out the front. Everything else works fine. The water runs even if I turn off the machine. I need to close the water mains to stop the water running.
    What can I do?
Replace hot water valve.
Posted on Sep 28, 2008
Will not start on some wash programs, such as 40 or 60 fast spin, but will work when 40 woolens program selected, and other delicate programs too.
Check that the hot water tap is on or if the valve filter is blocked. If both these are ok, it may need a new hot water valve.
Hope this helps.
Use link item 171295 on page 4
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFK2401UC%2f01&ESHOPTYPE=S
Aug 21, 2010 | Bosch WFK 2401
Our Bosch WFK 2401 keeps filling with hot water - even when a cold cycle is selected.
The problem is the water inlet valve has failed. Although it is only the cold water the whole valve needs to be replaced. There are 2 solenoids on the valve 1 for cold 1 for hot the cold water solenoid has failed. The reason it works in the softner is it uses a separate solenoid to let water in there.
Check the below link , it might be useful;
http://appliancehelponline.com/washerwaterinlet.html
Jul 21, 2010 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
Bosch WFK 2401On/Off Switch
You need a new switch should be able to buy on its own note wiring before doing.. it just pops out i think..good luck
Sep 08, 2009 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 hot water wont shut off even if you turn power off
I can help , If the unit is leeting water in with the power off the only thing it can be is the water inlet valve , it is the componet you connect your water line to under the unit behind the front lower panel. Tell me if you have any other questions and let me know how this works out.
Phil
Jan 07, 2009 | Bosch WFK 2401
Bosch WFK 2401 Washing Machine On/Off Switch Replacement
TRy www.espares.co.uk/bosch
or www.bosch-spareparts.co.uk
If it runs o/k with the switch held in .\then all youneed is a new switch.
Plz rate my advice.
Thanks.
Jan 03, 2009 | Bosch WFK 2401
Bosch washing machine won't spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Oct 26, 2008 | Bosch WFK 2401
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Washing Machines Logo
155 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Richard Roth
Richard Roth
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
